adonato
Blocking youtube
Tue Aug 09, 2022 2:51 am
Hi to all.
I know this is a old thread, but maby you can help. I have a mikrotik in my house rb 750. And I want to block using YouTube to my kids, can you share some to do it ? Thank you!
own3r1138
Long time Member
Long time Member
Re: Blocking youtube
Tue Aug 09, 2022 4:02 am
Place this rule above your fast-track rule.
add action=drop chain=forward protocol=tcp tls-host=*youtube*
vecernik87
Forum Veteran
Forum Veteran
Tue Aug 09, 2022 9:16 am
That would work reliably maybe 10 years ago but for quite a while, google uses QUIC. Nowadays, youtube runs HTTP/3 built on top of QUIC, which means the TLS is inside of QUIC itself and TLS matcher will not work.
This rule will work only if the device never loaded youtube in the past. If your device started youtube at least once in the past, videos will work just fine.
anav
Tue Aug 09, 2022 3:53 pm
Yes but own3r is from pleiades and probably doesnt know the progress made on earth since his last visit.
rextended
Tue Aug 09, 2022 3:59 pm
@adonato
search instead of opening useless topic about what already exist.
for example:
Block Youtube on computers and smartphone apps
viewtopic.php?t=188288
Users browsing this forum: BoraHorza, holla29, jaclaz, JeffreyAxori, Majestic-12 [Bot], markinhusxp and 207 guests
