matamouros
CAPsMAN: only one pre-configured channel per configuration?
Tue Aug 09, 2022 3:47 am
Hi, I've predefined a bunch of channels on 2.4 and 5GHz - nothing arcane, just the regular stuff for the country I'm in. But I seem to only be able to add one of those channels per configuration - is that right or am I missing something? What's the recommended way to list a bunch of pre-configured channels on my configuration on Winbox (with custom tx power, width, etc), so that CAPsMAN chooses from a list instead either just one or whatever it damn well pleases?
In the screenshot below you can see that I can only add one channel - do I need multiple configurations, one for each channel? (surely not, right?)
holvoetn
Re: CAPsMAN: only one pre-configured channel per configuration?
Tue Aug 09, 2022 9:17 am
On the channel tab, you have the option to specify multiple frequencies if you use the down-pointing arrow.
Adjust name accordingly.
But ... that may result in closeby CAPs using the same channel-definition to be operating on the same frequency (hence disturbing each other), which may not be what you want.
Ca6ko
Long time Member
Long time Member
Tue Aug 09, 2022 1:30 pm
It is best to select the channels manually. Automatic frequency selection does not work well yet.
The frequency can be set directly in the CAP interface
gotsprings
Wed Aug 10, 2022 12:14 pm
Another vote for manual channel setting.
Users browsing this forum: No registered users and 83 guests
