aSelfLion
'[get $i active-host-name]' only when I add this part; 'input does not match any value of value-name'
Tue Aug 09, 2022 1:34 pm
Hello
I am getting an error as 'input does not match any value of value-name'.
My script is as below
:foreach i in=[find] do={:put ([get $i block-access].','.[get $i address].','.[get $i mac-address].',' .[get $i client-id].','.[get $i server].','.[get $i active-address].','.[get $i active-mac-address].' ,'.[get $i active-host-name]) }
I get this error.
mrz
Re: '[get $i active-host-name]' only when I add this part; 'input does not match any value of value-name'
Tue Aug 09, 2022 1:55 pm
From which menu? Are you sure that this parameter even exist in the menu you are trying to get it from?
aSelfLion
Tue Aug 09, 2022 3:03 pm
I am absolutely sure.
I took a screenshot. attached.
mrz
Tue Aug 09, 2022 3:14 pm
no there isn't,
write in the terminal "get 0" and press tab to see all the valid parameter names.
aSelfLion
Tue Aug 09, 2022 3:30 pm
It also brings only 1000 thread lists in the terminal.
I have a list of 1500 threads.
How can I get them all?
Or I can export to an excel sheet or csv or txt.
aSelfLion
no there isn't,
I did not understand or could not do this.
Could you give an example, please.
rextended
Tue Aug 09, 2022 3:32 pm
Maybe if you pay atteNtioN to how you write ... oN the forum you wrote one thiNg, in the screeNshot there is aNother !!!
active-host-name do not exist, you must use host-name
try to avoid morse code '.'.'.'.'.' ...
    :put "$[get $i block-access],$[get $i address],$[get $i mac-address],$[get $i client-id],$[get $i server],$[get $i active-address],$[get $i active-mac-address],$[get $i host-name]"
aSelfLion
Tue Aug 09, 2022 3:44 pm
Teşekkürler
rextended
Tue Aug 09, 2022 3:55 pm
aSelfLion
Tue Aug 09, 2022 4:04 pm
aSelfLion
Tue Aug 09, 2022 4:12 pm
My friend;
rextended
Tue Aug 09, 2022 4:19 pm
You have 1500 threads items?
Where you read it?
try
print count-only
and see what number appear
aSelfLion
Tue Aug 09, 2022 4:27 pm
Where you read it?
try
print count-only
It looks like 1260 pieces.
The hotel has a hotspot that's why it's so much.
Now I need to extract them somewhere in my cvs txt or xlsx format.
rextended
Tue Aug 09, 2022 4:30 pm
MikroTik have 4095 byte for (managed by script) file limit, the list can't be stored on one unique file from the script
aSelfLion
Tue Aug 09, 2022 4:53 pm
So how can I get all of these ip and mac addresses? Is there any other management?
rextended
Tue Aug 09, 2022 4:58 pm
I don't know what to suggest, you can do
/ip dhcp-server lease print terse file=namefile
but then you have to process later the file with the computer
aSelfLion
Tue Aug 09, 2022 5:26 pm
Believe me, that's exactly what I was trying to do. I think it will do my job.
But what I really want to do is actually.
I want to extract the excel file with vba and follow some controls online. Maybe I can.
If I can find a clue an example I can do the rest somehow.
Thank you.
Users browsing this forum: Bing [Bot] and 26 guests
