dabodae
Problem with 6.** version
Tue Aug 09, 2022 5:41 pm
Hello everyone,
I have this architecture that I m posting. I want to configure the Mikrotik to have a dhcp wlan that permits me to ping my top client with static configuration. I have set this configuration:
add name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no frequency=auto mode=ap-bridge ssid=MikroTik-TRY \
wireless-protocol=802.11
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=Try123
add name=dhcp ranges=192.168.1.10-192.168.1.41
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge ingress-filtering=yes interface=wlan1
add bridge=bridge ingress-filtering=yes interface=ether1
add interface=bridge list=LAN
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
add address=192.168.1.2/24 interface=wlan1 network=192.168.1.0
add address=192.168.1.0/24
set allow-remote-requests=yes
/system routerboard settings
set silent-boot=no
When I try to apply it to a Mikrotik with 7.* version it works, while with 6.* it doesn t: it sets the wlan1 in station mode and delete my dhcp server configuration.
Any advice?
Thank you everyone
dabodae
Re: Problem with 6.** version
Thu Aug 11, 2022 2:15 pm
Any suggest?
bpwl
Thu Aug 11, 2022 2:36 pm
Almost there.
There should not be any difference between ROS 6 and ROS7 in this simple network.
But ....
- there are no VLAN seen in your config. So remove the ingress-filtering on the bridge ports.
- a WLAN in station mode is a client device to an other AP. You have clients to the mAP, so the WLAN should be in "AP-bridge" operation mode, as your config printout is saying.
Just wonder: there might be a requirement that your pre-shared key is minimum 8 characters long, "Try123" is too short.
(https://www.skillset.com/questions/what ... characters)
afuchs
Thu Aug 11, 2022 2:55 pm
Mmm...
are you sure your Client answer ping requests?
Windows drop ping requests per default untill you allow it in the (Windows Defenser) Firewall (https://kb.iu.edu/d/aopy).
dabodae
Thu Aug 11, 2022 3:57 pm
Thank you both for your help
Almost there.
But ....
I set ingress-filtering=no and now I can see the wifi (mikrotik led blinks now and I can see the wifi network on my pc), but the dhcp doesn t work (I post you a screen)
PS: I changed the wifi key with the right requirement
Mmm...
Yes I don t have ping problems, the same mikrotik with 7* version it works perfectly
mkx
Thu Aug 11, 2022 4:25 pm
You only need single IP address from subnet 192.168.1.0/24 and that one should be on bridge interface.
anav
Thu Aug 11, 2022 4:44 pm
Your architecture is not clear, and where is the internet?
Do you have one or two LAN subnets?
The config is as confused as your diagram
dabodae
Thu Aug 11, 2022 4:47 pm
Done, now I just connected my iPhone to wifi, it assigns me 192.168.1.254 (I can see it in "leases" tab too) but i can t ping it:
anav
Thu Aug 11, 2022 5:10 pm
Why did you change your network and config............
Did your requirements change or are you blindly listening to advice..................
Please provide
a. a proper network diagram showing the equipment involved, the WAN connection and the ports with conceptually which subnets/vlans should be traversing.
b. latest config
dabodae
Thu Aug 11, 2022 5:25 pm
I m sorry I didn t see your reply.
I don t have internet, I d like have a wifi network where i can connect with multiple devices (so i used dhcp server) and be able to ping and use my static device (the top client you can see in my first diagram, with static ip 192.168.1.42). Idk why configuration i set (in my first post) works in 7* version and not in 6*.
I just have a constraint, to not set the gateway in the dhcp server, so when i m connected to wifi with my smartphone, i can use my mobile data to have internet (viewtopic.php?p=937604#p937604)
dabodae
Thu Aug 11, 2022 5:33 pm
Please provide
b. latest config
I have a static device X:
- 192.168.1.42
- 255.255.255.0
I want connect X to mikrotik via ether1, and have a wifi where i can connect and navigate to X via its ip.
As told in the latest topic, i don t want to add a gateway to my dhcp server to be able to use my mobile data while i m connected to wifi.
anav
Thu Aug 11, 2022 6:09 pm
Thanks the contsraint noted is helpful to be aware of.
Why not just turn wifi off when you want to use data ??
dabodae
Thu Aug 11, 2022 6:24 pm
Because i have to send data from internet in real time while i m connected to wifi network. However if i reset my mikrotik and send this configuration:
:local count 0;
:while ([/interface ethernet find] = "") do={
:if ($count = 30) do={
:log warning "DefConf: Unable to find ethernet interfaces";
/quit;
:delay 1s; :set count ($count +1);
:local count 0;
:while ([/interface wireless print count-only] < 1) do={
:if ($count = 40) do={
:log warning "DefConf: Unable to find wireless interface(s)";
/ip address add address=192.168.88.1/24 interface=ether1 comment="defconf";
/quit
:delay 1s;
add name=bridge
/interface wireless
disabled=no frequency=auto mode=ap-bridge ssid=MikroTik-6 \
add name=LAN
dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=Try123456789
add bridge=bridge ingress-filtering=no interface=wlan1
add bridge=bridge ingress-filtering=no interface=ether1
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
set silent-boot=no
It freezes all:
anav
Thu Aug 11, 2022 6:32 pm
Good information that should have been stated on the first post LOL, but we will get there.
So the internet connection is your IPhone and its connected to the MT network via wifi.
You need to be connected at the same time to the internet and the MT via wifi to pass on real time traffic from LAN device.
dabodae
Thu Aug 11, 2022 7:15 pm
Yes, I m open to new configurations, if you have better solution
dabodae
Tue Aug 23, 2022 10:37 am
Someone can help me with this architecture?
Recap:
- 192.168.1.42
- 255.255.255.0
I want connect X to mikrotik map lite via ether1, and have a wifi where i can connect and navigate to X via its ip.
Important: i don t want to add a gateway to my dhcp server to be able to use my mobile data (for internet) while i m connected to wifi.
bpwl
Tue Aug 23, 2022 11:10 am
Adding gateway will not influence access to 192.168.1.42 from any other 192.168.1.yyy (this is local LAN, not via gateway).
Set WLAN1 in the WAN interface list. Bridge (and all it's ports) are in the LAN interface list.
Users browsing this forum: Google [Bot] and 82 guests
