sy4
IKEv2 RoadWarrior + IPSec Site-to-Site NAT Issue
Wed Aug 10, 2022 10:58 am
I have two policy based IPsec site-to-site tunnels connecting two sites B and C, at Site A on a MikroTik RB760iGS that works flawlessly. I have an IKEv2 RoadWarrior remote access setup on the Tik that works correctly as well. I am running into issues when trying to get RoadWarrior clients to connect to Site B or C. When pinging from the RoadWarrior, the ICMP packet makes it to the destination computer, and the ping reply makes it back to the Tik but not back to the RoadWarrior client at 10.0.80.254
Here's a detailed breakdown of what's going on:
RoadWarrior pool is 10.0.80.0/24
Site A (MikroTik) LAN is 10.10.20.0/24
Site B LAN is 192.168.2.0/24
Site C LAN is 192.168.3.0/24
I have a masquerade rule to change 10.0.80.0/24 into 10.10.20.0/24 before heading to Site B
add action=masquerade chain=srcnat dst-address=192.168.2.0/24 log=yes \
    out-interface=bridge src-address=10.0.80.0/24 to-addresses=10.10.20.0/24
and added Site B to the routes list
add disabled=no dst-address=192.168.2.0/24 gateway=bridge routing-table=main \
    suppress-hw-offload=no
After some packet sniffing with Wireshark, I could see that ping from the Road Warrior reaches the destination computer at Site B. The ping reply makes it back to the Tik at Site A but does not make it to the Road Warrior client.
Looking at the firewall log, I can see that the ping gets srcnat'ed and heads to the destination
forward: in:ether1 out:bridge, connection-state:new,snat , proto ICMP (type 8, code 0), 10.0.80.254->192.168.2.61, NAT (10.0.80.254->10.10.20.1)->192.168.2.61, len 60
and ping reply from the destination comes back
forward: in:ether1 out:ether1, connection-state:established,snat , proto ICMP (type 0, code 0), 192.168.2.61->10.0.80.254, NAT 192.168.2.61->(10.10.20.1->10.0.80.254), len 60
The only thing that looks odd to me is that the out interface is ether1 instead of bridge.
Am I missing something obvious here? :-?
sy4
Re: IKEv2 RoadWarrior + IPSec Site-to-Site
Wed Aug 10, 2022 8:38 pm
Here's the full configuration on the Tik
# aug/10/2022 09:31:54 by RouterOS 7.4
# software id = 49UR-2U4T
# model = RB760iGS
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf igmp-snooping=yes \
    name=bridge
add name=bridge-loopback
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec peer
add address=public.ip.site.b/32 name=IPsec-Site B
add address=public.ip.site.c/32 name=IPsec-Site C
/ip ipsec policy group
add name="group vpn.ikev2.xyz.com"
/ip ipsec profile
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128 \
    hash-algorithm=sha256 name="profile vpn.ikev2.xyz.com"
/ip ipsec peer
add exchange-mode=ike2 local-address=public.ip.site.a name=\
    "peer vpn.ikev2.xyz.com" passive=yes profile=\
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,aes-128-ctr \
    pfs-group=modp2048
add auth-algorithms=sha512,sha256,sha1 enc-algorithms="aes-256-cbc,aes-256-ctr\
    ,aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm" \
    lifetime=8h name="proposal vpn.ikev2.xyz.com" pfs-group=none
add name="pool vpn.ikev2.xyz.com" ranges=10.0.80.2-10.0.80.254
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
/ip ipsec mode-config
add address-pool="pool vpn.ikev2.xyz.com" address-prefix-length=32 name=\
    "modeconf vpn.ikev2.xyz.com" split-include=10.10.20.0/24 static-dns=\
    10.10.20.250 system-dns=no
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=all
/interface detect-internet
set detect-interface-list=all
add address=10.10.20.1/24 comment=defconf interface=bridge network=10.10.20.0
add address=10.0.80.0/24 interface=bridge-loopback network=10.0.80.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no use-peer-ntp=no
add address=192.168.1.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
    192.168.1.254 netmask=24
set allow-remote-requests=yes servers=10.10.20.250
/ip dns static
add address=192.168.1.254 comment=defconf name=router.lan
add action=accept chain=input protocol=ipsec-esp
    established,related,untracked
    invalid
    "Allow UDP 500,4500 IPSec for public.ip.site.a/22" dst-address=public.ip.site.a \
    dst-port=500,4500 protocol=udp
add action=accept chain=input comment="Allow IPsec-esp for public.ip.site.a/22" \
    dst-address=public.ip.site.a protocol=ipsec-esp
    "IKEv2: Allow ALL incoming traffic from 10.0.80.0/24 to this RouterOS" \
    ipsec-policy=in,ipsec src-address=10.0.80.0/24
    in-interface-list=!LAN
    "IKEv2: Allow ALL forward traffic from 10.0.80.0/24 to Anywhere" \
    dst-address=10.0.80.0/24
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=srcnat comment="IPsec Admin NAT" dst-address=\
    10.0.20.0/24 src-address=10.10.20.0/24
add action=masquerade chain=srcnat comment=\
    "SRC-NAT\r\
    \nIKE2:10.0.80.0/24 --> ether1 traffic" disabled=yes src-address=\
    10.0.80.0/24 to-addresses=public.ip.site.a
    "MSQRD IKE2:10.0.80.0/24 -->\r\
    \nWAN traffic\"" disabled=yes ipsec-policy=out,none out-interface-list=\
    WAN src-address=10.0.80.0/24
add action=accept chain=srcnat comment="IPsec Site B-Site A NAT" dst-address=\
    192.168.2.0/24 src-address=10.10.20.0/24
add action=accept chain=srcnat comment="IPsec-Site C-Site A NAT" \
    dst-address=192.168.3.0/24 src-address=10.10.20.0/24 src-address-list=""
/ip ipsec identity
add peer=IPsec-Site B
add peer=IPsec-Site C
add auth-method=digital-signature certificate=vpn.ikev2.xyz.com \
    generate-policy=port-strict match-by=certificate mode-config=\
    "modeconf vpn.ikev2.xyz.com" peer="peer vpn.ikev2.xyz.com" \
    policy-template-group="group vpn.ikev2.xyz.com" remote-certificate=\
    admin@vpn.ikev2.xyz.com remote-id=user-fqdn:admin@vpn.ipsec.xyz.com
/ip ipsec policy
set 0 disabled=yes
add dst-address=192.168.2.0/24 peer=IPsec-Site B src-address=10.10.20.0/24 \
    tunnel=yes
add dst-address=192.168.3.0/24 peer=IPsec-Site C src-address=10.10.20.0/24 \
    tunnel=yes
add dst-address=10.0.80.0/24 group="group vpn.ikev2.xyz.com" proposal=\
    "proposal vpn.ikev2.xyz.com" src-address=0.0.0.0/0 template=yes
add disabled=no distance=1 dst-address=10.0.80.254/32 gateway=bridge \
    pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip smb
set domain=MMPBC
/ip upnp
set enabled=yes
/ip upnp interfaces
add forced-ip=public.ip.site.a interface=ether1 type=external
add interface=bridge type=internal
/ipv6 firewall address-list
add address=2001:10::/28 comment="defconf: ORSite AID" list=bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system identity
set name=Site A-Router
/system ntp client
set enabled=yes
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: No registered users and 151 guests
