jskryja
Synology HTTPS over WAN
Wed Aug 10, 2022 1:18 pm
Hello, I got 2 networks. i want to be able connect from Location 1 WAN address to Synology DSM over https. Can you help me please, how should I do it?
Location 1:
I am here with my local IP 192.168.1.2 (example) and our WAN is 35.35.35.35
Location 2:
MikroTik where is WAN IP 35.35.35.36 and Synology in LAN 10.0.1.2.
anav
Re: Synology HTTPS over WAN
Wed Aug 10, 2022 2:44 pm
Why not just create a vpn tunnel such as wireguard between the two mikrotik routers and thus lan clients at the remote end can access the synology device as required and securely.
jskryja
Wed Aug 10, 2022 3:31 pm
Good idea, which vpn would you recommend to me?
erlinden
Wed Aug 10, 2022 3:45 pm
:roll:
anav
Wed Aug 10, 2022 4:09 pm
Not ikve
Not openvpn
Not ppp variant of anything
not port knocking
not lt2p
Not any other acronymn that doesnt start with the letter W.
You still havent identified equipment at both sides of a potential future connection?
Please draw a network diagram to show equipment connected, and subnet flows going over ports, and ISP connections etc...
Sob
Wed Aug 10, 2022 9:29 pm
IPSec is not bad either. It works best with static public addresses at both sides, but it's not hard requirement. And if you have right devices, it will be even HW accelerated.
Users browsing this forum: Bing [Bot], kolt and 11 guests
