blingblouw
Cube 60Pro ac
Wed Aug 10, 2022 3:34 pm
Hi.
Just wondering how to enable channel bonding (is it supported?) on the Cube 60Pro ac?
I see there are a bunch of options (channel-bonding, beamforming, tx-power, physical-setup, etc) that are read-only that cannot be set, is this coming with a later firmware upgrade? Currently running ROS7.4.1
[admin@MikroTik] /interface/w60g> print
 0   name="wlan60-1" mtu=1500 l2mtu=1600 mac-address=11:11:11:11:11:11
     arp=enabled arp-timeout=auto region=usa mode=bridge physical-setup=static
     ssid="MikroTik" frequency=auto channel-bonding=off
     default-scan-list=58320,60480,62640,64800,66960 force-freq=off password=""
     firmware="" board-file="" mcs=0-15 beamforming=yes
     max-tx-queued-bytes=auto tx-ring-size=4096 rx-ring-size=1024
     tx-power=default tx-sector=auto rx-power=default
     put-stations-in-bridge=none isolate-stations=yes
     terragraph-peer-mac=00:00:00:00:00:00 terragraph-fw-params=""
[admin@MikroTik] /interface/w60g> set
<numbers> -- List of item numbers
arp -- Address Resolution Protocol
arp-timeout --
comment -- Short description of the item
disabled -- Defines whether item is ignored or used
frequency --
isolate-stations --
l2mtu --
mac-address --
mdmg-fix --
mode --
mtu -- Maximum Transmit Unit
name -- Interface name
password --
put-stations-in-bridge --
region --
scan-list --
ssid --
tx-sector --
server8
Long time Member
Long time Member
Re: Cube 60Pro ac
Sat Aug 13, 2022 11:49 am
Official answer from mikrotik is needed
Users browsing this forum: Bing [Bot] and 16 guests
