dnwklin
Unable to reset my RB960
Thu Aug 11, 2022 8:12 pm
My RB960 is runnong on 7.3.1. However, it doesn't seem like I can reset it or remove any packages from it.
I tried reset in the winbox or terminal. It will reboot but not reset to default. I try to press reset button while applying power, it did not react to the reset button pressed.
I also try to uninstall some extra package I installed and it won't let me reinstall. I try to upgrade to 7.4.1 and it also won't let me upgrade. Everytime it reboot, it looks like back to the status before I reboot it.
Any idea?
k6ccc
Re: Unable to reset my RB960
Fri Aug 12, 2022 1:12 am
NetInstall.
Export config before you do so. You can use the export to put the config back after the NetInstall.
Users browsing this forum: Ahrefs [Bot], gkhun, ramin110, Wintxi and 133 guests
