neok
Wrong outgoing public IP
Thu Aug 11, 2022 9:29 pm
Hello everyone.
I need to make the outgoing IP to the internet x.y.z.110 and not a.b.c.214. My ISP gave me a /30 for the WAN side and a /29 for the LAN side of my router.
While the internet connection is working fine, when I check the outgoing IP I realize that it is not what it should be. I think I have a NAT misconfiguration somewhere but I don't know where.
Attached is a diagram and the configuration of my router.
Any help you can give me will be more than appreciated.
Thank you very much.
Best regards.
Gabriel
# jul/29/2022 11:55:24 by RouterOS 6.47.10
# software id = DC59-QRN0
# model = RB760iGS
# serial number = XXXXXXXXXXXX
add admin-mac=DC:2C:6E:17:31:8E auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=none
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge network=192.168.88.0
add address=a.b.c.214/30 interface=ether1 network=a.b.c.112
add address=x.y.z.105/29 interface=ether2 network=x.y.z.104
add address=10.250.250.152/24 interface=bridge network=10.250.250.0
/ip cloud
set update-time=no
set servers=8.8.8.8,1.1.1.1
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="Allow SNMP from Zabbix" dst-port=161 protocol=udp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=a.b.c.213 pref-src=0.0.0.0
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/snmp
set contact="John Doe <jdoe@gmail.com>" enabled=yes location="Data Center Of. 59 - Rack 5"
/system clock
set time-zone-name=America/Argentina/Buenos_Aires
/system identity
set name=GW_LUMEN1
/system ntp client
set enabled=yes primary-ntp=216.239.35.4 secondary-ntp=162.159.200.123 server-dns-names=8.8.8.8,1.1.1.1.
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Sob
Re: Wrong outgoing public IP
Fri Aug 12, 2022 12:03 am
Instead of action=masquerade (which selects address automatically), use action=src-nat to-addresses=x.y.z.110.
jvanhambelgium
Forum Veteran
Forum Veteran
Fri Aug 12, 2022 12:11 am
Don't use the NAT ? Why use NAT if your Fortigate101F can do that for you ? That Fortigate can make all internal 10.x.x.x traffic coming out as x.y.z.110
All the rest is just routing.
Sob
Fri Aug 12, 2022 12:35 am
Or that ^^^, even better. But if you need NAT for 10.250.250.0/24 subnet, then exclude public subnet from srcnat using src-address=!x.y.z.104/29.
jvanhambelgium
Forum Veteran
Forum Veteran
Fri Aug 12, 2022 8:27 am
I did not even look at the config-file but only the picture. :D
Then he better had some extra segment 10.250.250.0/24 & 192.168.88.0/24 on the picture.
Yeah, in that case IF that 10.250.250.x and/or 192.168.88.0/24 needs Internet access then NAT is mandatory on the Mikrotik again.
neok
Fri Aug 12, 2022 4:13 pm
Thank you very much for the answers. Sorry, I forgot to mention, I don't need internet access from the networks 10.250.250.0/24 nor from 192.168.88.0/24. Only from 10.10.40.0/22.
So, if I understood correctly, I just remove the NAT from my Mikrotik router and with that I would have it solved, right?
Thanks again.
Best regards
Gabriel
jvanhambelgium
Forum Veteran
Forum Veteran
Fri Aug 12, 2022 5:05 pm
Yep, that should do it. Give it a try.
Sob
Fri Aug 12, 2022 5:10 pm
And if you want x.y.z.110 to handle own firewalling for incoming connections, you should remove the last filter rule in forward chain.
neok
Wed Aug 24, 2022 8:49 pm
I change NAT from masquerade to accept and disable last firewall policy and everithing is working that I whish.
Thanks for the help.
Best regards,
Gabriel
Users browsing this forum: actomobile, deatras, GoogleOther [Bot], jbolakakis, sbert, tntx777 and 123 guests
