mrmcrae
LHG60 Base Config to support VLANs
Fri Aug 12, 2022 12:55 pm
I have inherited the task of setting up a P2P bridge using 2 x LHG60ad. I have zero experience using Mikrotik.
I have used the Quick Set and had LHG60(A) as the bridge and LHG60(B) as a Station Bridge and can see activity in the Signal and MCS graphs so I'm assuming their connected in some form. It wouldn't take the management ip address so I'm assuming its done under interfaces.
Topology
L3 SW - L2 SW - LHG60(A) -------- LHG60(B) - L2 SW
Basic Requirements:
Management - VLAN105
Client - VLAN20
Voice - VLAN65
Note - I am led to believe that VLAN1 is in use in the network.
Does anyone have base configs each for LHG60(A) and LHG60(B) to get this bridge up with the above basic requirements.
This would be a huge help and would be a good start to trying to understand. Current documentation I have found to be confusing and doesn't seem to work :P
TIA
Users browsing this forum: Majestic-12 [Bot] and 41 guests
