muk
Add User Manager
Fri Aug 12, 2022 5:59 pm
Hi
Dear MikroTik Team..!!
Currently I'm using RB951 router board and version update from 6,48 to 6,49
i want to use RADIUS Server
I'm adding the User Manager Services in Files but not load in Packages Tab..
what can i do for this...??
suggest the best solution, please.
rextended
Re: Add User Manager
Fri Aug 12, 2022 6:44 pm
Reboot the device?
muk
Fri Aug 12, 2022 6:52 pm
Reboot the device?
reboot device multiple times but still same situation
bpwl
Fri Aug 12, 2022 7:09 pm
What is in the LOG after the reboot ?
Users browsing this forum: ringrring, unhuzpt and 103 guests
