Radovan11
Router hAP RB951Ui-2nD- error
Sat Aug 13, 2022 2:38 pm
Please, I have a mikrotik hAP RB951Ui-2nD router and after the firmware update, the router did not start, only the PWR and USR lights are on, the ports do not light or flash at all, and I cannot log in to the router, even if I press the reset button, the router is simply dead. Could it please be fixed in some way or reinstall the firmware, or is it already dead. Thank you Radovan
chechito
Re: Router hAP RB951Ui-2nD- error
Sat Aug 13, 2022 4:15 pm
Netinstall is the procedure to recover device form software failure like this
check this guide item H
viewtopic.php?t=182373
Radovan11
Sat Aug 20, 2022 2:03 am
Děkuji mockrát, vyřešil jsem to přes ten netinstall, už router funguje. Děkuji moc Radovan, vyřešeno
Users browsing this forum: Amazon [Bot], GoogleOther [Bot], tangent, tryrtryrtryrt and 112 guests
