TaifunTux
Cann't connect to wAP-AC
Sun Aug 14, 2022 7:57 pm
I have a wAP-AC, which was successfully configured last year, but has now been permanently installed. Now I am unable to connect to the device via Ethernet. I have already performed a reset several times. I am using Linux Mint 20.3 and autoconnect does not connect. Does anyone know a solution?
erlinden
Re: Cann't connect to wAP-AC
Sun Aug 14, 2022 11:29 pm
On resetting to defaults the wAP-AC will have an open wireless network. Have you tried to connect to that? It might have a firewall configured on the ethernet port.
TaifunTux
Mon Aug 15, 2022 10:26 am
I have performed a reset and can see the wireless network, but it is protected. Could the reset have been unsuccessful?
Now on a Windows laptop with WinBox tried, but also without result.
ipconfig:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::3593:ae46:ea58:ab8c%19
IPv4 Address. . . . . . . . . . . : 192.168.88.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
TaifunTux
Re: Cann't connect to wAP-AC  [SOLVED]
Mon Aug 15, 2022 12:15 pm
It all seemed to be resolved, the reset apparently went wrong. The old ip address and password were still active. But now I have another problem. The POE seems to be broken. The power light is off.... :(
Users browsing this forum: No registered users and 63 guests
