İmposss
Bandwidth test not work with link-local address
Mon Aug 15, 2022 1:29 am
Hi. I have two hap ac2 connect with cable. I have ipv4 and ipv6 addresses and connections. Bt test working behind two devices with ipv4 (local) and global ipv6 address. But bt test is not work with link-local address (fe80::/64)
Thanks.
Sob
Re: Bandwidth test not work with link-local address  [SOLVED]
Mon Aug 15, 2022 4:29 am
It works, but you have to specify interface as part of address (fe80:xxxxxxxx%etherx), that's normal for link-local addresses.
İmposss
Mon Aug 15, 2022 12:35 pm
İt is working thankyou. :)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], GoogleOther [Bot], korg and 98 guests
