joschwe
NAT behaviour
Mon Aug 15, 2022 6:17 pm
as of lately clients that connect to 2 different servers on either port 80 or 8080 within the same network experience frequent connection losses (the web applications stop working and kick them out and reconnect again). I haven't found out why yet.
One thing I noticed is that I get the following NAT behaviour
where SYN messages are sent to ip adresses that aren't in use. Starting from lets say x.x.x.98 going to x.x.x.107 .
Is this behaviour expected? Let me know which configuration details you need.
Also while looking for the version number of RouterOS I got the following:
which looks as though I haven't upgraded RouterOS but I am pretty sure I did this already.
thanks and best
Znevna
Re: NAT behaviour
Mon Aug 15, 2022 7:21 pm
Provide an anonymized config export.
7.2.1 is rather old, and by the screenshot provided it looks you didn't upgrade the firmware (from the RouterBOARD menu, the exact one you've posted).
anav
Re: NAT behaviour
Mon Aug 15, 2022 7:26 pm
Yup, config is required,
Nice to have network diagram.
Two main issues with port forwarding,
How public is your WAN IP
Are you using WANIP for internal LAN users.
viewtopic.php?t=179343
joschwe
Re: NAT behaviour
Fri Aug 19, 2022 4:45 pm
Thank you a lot for the replies. I suspected NAT hairpin and will read into it. Also I will make a network diagram and attach it.
Please find attached an anonymized config file.
Yes, some users do, some don't. But using the local ip of the servers didn't fix the issue.
best,
anav
Re: NAT behaviour
Fri Aug 19, 2022 4:56 pm
(1) You should update to 7.4.1 firmware, less bugs and more stable.
(2) Someone else can assist, I dont help those who configure vlan-id=1
(3) Cannot understand your pool structure
(4) Do not understand why you need two bridge
(5) Do not understand the lack of consistency in number of vlans, dhcp-server, dhcp-server-networkls, IP pools, and IP addresses
(6) I think your mixing up use of forward chain and NAT chain for port forwarding.
(7) Total lack of default and expected firewall rules
(8) Not sure why you have a route rule for a public DNS server?
(9) Not clear why you are mangling as dont understand your wan situation.
In summary I find this is a confusing config that is either genius put together and above my limited knowledge or a hodge podge of internet searched rules cobbled together. ?????
joschwe
Re: NAT behaviour
Fri Aug 19, 2022 5:40 pm
It's neither. Most things aren't active/in use. I mean it's obviously a double NAT configuration. I can clean this up, though. I tested a lot of stuff in the beginning and was confused on how to delete some of the things or didn't bother.
The only things that are important is the bridge with 192.168.178.0/24 ip pool and the 2 wan interfaces.
And the question is why the connection between a server on 192.168.178.3 and the clients on 192.168.178.20-150 is getting interrupted every now and then.
Ok.
I don't use any VLans
Only DHCP pool #10 is in use.
There is one bridge for the 192.168.178.0/24 adresses and another one that was a default for configuring a connection to the router I think.
192.168.178.0/24 - Clients and Server
192.168.176.254 - Wan 1 goes to a Fritzbox
192.168.179.254 - Wan 2 goes to another Fritzbox
How would I port forward otherwise? Let's say from 192.168.176.254:8080 to 192.168.178.3:8080
It's a double NAT setup. Firewall rules are in place on the routers connected to the ISPs
Recursive routing failover.
I wanted load balancing between the 2 WAN ports but didn't manage to make sure that the gateway where the request came in was the same gateway the response was sent to. So I configured one line as failover instead of load balancing. All mangling rules are disabled, I thought its visible in the config. I don't want to delete them as I think they worked mostly and I may need them again.
best
Users browsing this forum: Ahrefs [Bot], GoogleOther [Bot], ips, llamajaja and 85 guests
