cairokee
Filter rule
Tue Aug 16, 2022 10:29 am
Hi guys
1- I want to lock all websites and phone applications for all users and open just Outlook for all users
2- Open all websites for some users
BartoszP
Re: Filter rule
Tue Aug 16, 2022 10:40 am
Open questions:
How do you want to recognize what programm makes connections? How to differentiate phone apps from non-phone ones?
Have you ever configured any router?
cairokee
Re: Filter rule
Tue Aug 16, 2022 11:18 am
A1:i don't know i just ask if i can do it by anyways im new in this
A2:Sure
BrateloSlava
Re: Filter rule
Tue Aug 16, 2022 12:01 pm
You will be able to block something only, when you learn to distinguish between devices. For example, allocate a separate range of IP addresses for phones. And for this range already perform some kind of blocking. But you will not be able to determine in any way, which application from this device is trying to get an Internet connection. You can try to block all connections, except outgoing to ports 80, 443 and 53. And see what happens.
P.S.
The task is to ensure that users at work do their work, and not "sit" in social networks, etc. from phones, did not play online games, etc. This task is not solved by means of the equipment of this company.
cairokee
Re: Filter rule
Wed Aug 17, 2022 9:18 am
but how open website for some users ?
BrateloSlava
Re: Filter rule
Wed Aug 17, 2022 11:09 am
Install a DHCP server. Create a range of IP addresses, that can access the Internet. Bind the IP address to the MAC of the device, that connects and receives the address.
Users browsing this forum: Google [Bot] and 19 guests
