BrainTrance
Mikrotik hAP lite RB941-2nd-TC Wifi SSID doesn't show up
Wed Aug 17, 2022 1:18 am
I was trying to configure this device and after many different fail configurations and hard resets it stopped showing up as an available wireless network.
Hard resets don't fix the problem. I press res/wps button I turn on the device and keep pressing until led is flashing, then I release the button, but nothing.
It was working fine until I powered on a Mikrotik hAP ac3 in order to do some configurations also in it. I'm just stating facts, I'm not assuming that this caused the problem.
Any suggestions?
bpwl
Re: Mikrotik hAP lite RB941-2nd-TC Wifi SSID doesn't show up
Wed Aug 17, 2022 1:49 am
Looks like you used the correct procedure: https://wiki.mikrotik.com/wiki/Manual:Reset
Should work, unless somebody has set routerboot-protection-mode : viewtopic.php?t=181158
(1 second blinking of the LED.)
You could not get in through ether2 , with WinBox? (Neighbor discover, MAC address connect)
Some USB console adapter or "Woobm-USB" MT stick to connect?
Next step would be "Netinstall", what has very strict requirements to execute.
BrainTrance
Wed Aug 17, 2022 2:20 am
When I press res/wps and power on the device the usr led which is off, just turns on. I suppose that's not considered as 1 sec flashing, right?
I can't get through ether2 (winbox). I change the IP address of my NIC to 192.168.88.2, I connect my PC to the device but when is trying to connect it fails.
I have no usb console adapter.
I suppose netinstall is my only choice now?
EDIT: I managed to connect with winbox via Neighbors as you said. I "reset all configuration" and now it's fixed. Thank you very much!
Users browsing this forum: jaclaz and 84 guests
