Giovannis
Problems with update in PBR
Wed Aug 17, 2022 1:54 am
I have been working fine until v7.2.1 and I have PBR (Policy Based Routing) implemented, I immediately upgrade to v7.2.2 onwards and on any later version the internet connection is lost for my clients however I can ping ips public for example 8.8.8.8 - 159.148.147.196 and they answer me the only solution is to disable PBR in the mangle and therefore I lose the advantages that PBR offers me; and the other solution is to go back to v7.2.1. where everything works normal. What am I doing wrong that I should implement as of v7.2.2?
Best regards.
rextended
Re: Problems with update in PBR
Wed Aug 17, 2022 2:06 am
Last version is 7.4.1
Giovannis
Wed Aug 17, 2022 2:10 am
Hello
rextended, I already did it even with 7.5beta8 and the problem continues.
rextended
Wed Aug 17, 2022 2:11 am
Yes, but ask for help on 7.4.1,
this is new default, and if you do not want stay stuck forever on previous version, now routing have precedence on mangling.
Search on forum, dozen of topic that ask and explain what is changed, etc. are already presents.
Users browsing this forum: No registered users and 40 guests
