Amplificator
Route FTP through WireGuard
Wed Aug 17, 2022 2:00 am
Hi.
I have tried setting up WireGuard (which seems to work) and I'm now trying to create a route for only FTP traffic to go through it - can this be done?
I have fiddled with mangle and routes but never got any of it to work, can someone please give me a helping hand?
anav
Re: Route FTP through WireGuard
Wed Aug 17, 2022 3:48 am
Sure provide a network diagram showing the devices in play,
Which device is the listening device for the connection.
Where is the FTP server located etc....
Provide config for the MT devices.
A basic example is provided..........
FTP is like any other service so nothing overly special. Create the tunnel properly using wireguard parameters.
Then ensure the firewall rules match needs/intention and then ensure routing exists for the traffic to move.
More detail here: viewtopic.php?t=182340
Ex: MT Router WANIP is x.y.w.z with lan subnet of 192.168.5.0/24 and FTP server at 192.168.5.25/32
Ex. MT other Device with lan subnet of 192.168.10.0/24
Ex IOS device
Main MT router
wireguard interface name=ftpwireguard
listening port=15555
PUBLIC Key for all peers................
ip address=10.10.10.1/24 interface=ftpwireguard
peer1 settings interface name=ftpwireguard (pulldown menu), Allowed IPs= 10.10.10.2/32.192.168.10.0/24 public key=FROM other MT device
peer2 settings interface name=ftpwireguard (pulldown menu), Allowed IPs=10.10.10.3.32 public key= from IOS device
OTHER MT DEVICE (peer1)
wireguard interface name=wireguard1
Public Key ------ TO GIVE TO MT ROUTER for peer settings.
ip address=10.10.10.2/24 interface=wireguard1
Peer Settings
wg name, pull down choice of wireguard1
Public Key -- From MT router.
Endpoint=x.y.w.z (or dyndns url)
Endpoint port=15555
Allowed address=10.10.10.0/24, 192.168.5.0/24
Persistent keep alive=25 secs
IOS DEVICE (peer2)
wireguard name = ioswireguard2
public key --> From MT Router
Address=10.10.10.3/32
DNS Server: 10.10.10.1
Peer Settings
Public Key TO GIVE TO MT ROUTER
Endpoint port=15555
Firewall rules,
allow traffic exiting the tunnel into a router locally from remote users is allowed to go where it needs to go.
allow traffic entering the tunnel originating from local users...... is allowed to do so
Routing rules
ensure traffic originating on a device has a path/route to enter the tunnel
ensure remote traffic has a return path/route back through the tunnel
Sob
Wed Aug 17, 2022 6:28 am
Unfortunately, FTP is special, because unlike more modern protocols, it uses separate connections for each data transfer (download, upload, directory listing), so working with them can be tricky. In depends on what you want to do. Hosting FTP server accessible via WG tunnel would be mostly ok. Having WG tunnel for outgoing connections to random FTP servers would be highly problematic. It may work with unencrypted FTP, if data connections inherit connection marks (I don't remember if they do and I can't test it right now). But with encrypted FTP, no way. You'd have to work with addresses, but if any other service would use same address, it would go via tunnel too.
anav
Wed Aug 17, 2022 2:04 pm
Good points by Sob that I didnt think about, I was strictly thinking that you were hosting an FTP server on the mikrotik router and were having users from other devices via wireguard access this FTP server.........
Users browsing this forum: Semrush [Bot] and 30 guests
