futureping
No link when connecting CCR2216-1G-12XS-2XQ QSPF28 interfaces
Wed Aug 17, 2022 3:13 am
Hi All
We recently purchased a new CCR2216-1G-12XS-2XQ and I am having trouble bring up the link between the device and two of our existing Cisco Nexus 3064-X devices. On the CCR side I am using both the QSFP28 interfaces to connect to the QSFP+ interfaces on the Nexus. I am also using 40G DAC cables from FS.com and I specified the encoding for each end of the cable. Before returning the cables I would like to rule out any misconfiguration on my end, which I assume is most likely the case. I am still new to Mikrotik and I was told that to bring the connection up I should only enable one of the interfaces and manually set the speed to 40Gbps but still no luck. Please see some of my configuration below
/interface export
# aug/16/2022 17:06:43 by RouterOS 7.4.1
# software id = I2YE-4LIK
# model = CCR2216-1G-12XS-2XQ
add name=bridge1
set [ find default-name=qsfp28-1-1 ] auto-negotiation=no comment=\
    "To nexus-1 Eth1/49" speed=40Gbps
set [ find default-name=qsfp28-1-2 ] disabled=yes
set [ find default-name=qsfp28-1-3 ] disabled=yes
set [ find default-name=qsfp28-1-4 ] disabled=yes
set [ find default-name=qsfp28-2-1 ] auto-negotiation=no comment=\
    "To nexus-2 Eth1/49" speed=40Gbps
set [ find default-name=qsfp28-2-2 ] disabled=yes
set [ find default-name=qsfp28-2-3 ] disabled=yes
set [ find default-name=qsfp28-2-4 ] disabled=yes
set [ find default-name=sfp28-1 ] comment="To nexus-1 Eth1/17"
set [ find default-name=sfp28-2 ] comment="To nexus-1 Eth1/18"
set [ find default-name=sfp28-11 ] comment="To ccr-2 on sfp28-11"
add name=WAN
add name=LAN
add bridge=bridge1 interface=qsfp28-1-1
add bridge=bridge1 interface=qsfp28-1-2
add bridge=bridge1 interface=qsfp28-1-3
add bridge=bridge1 interface=qsfp28-1-4
add bridge=bridge1 interface=qsfp28-2-1
add bridge=bridge1 interface=qsfp28-2-2
add bridge=bridge1 interface=qsfp28-2-3
add bridge=bridge1 interface=qsfp28-2-4
add bridge=bridge1 interface=sfp28-1
add bridge=bridge1 interface=sfp28-2
add bridge=bridge1 interface=sfp28-3
add bridge=bridge1 interface=sfp28-4
add bridge=bridge1 interface=sfp28-5
add bridge=bridge1 interface=sfp28-6
add bridge=bridge1 interface=sfp28-7
add bridge=bridge1 interface=sfp28-8
add bridge=bridge1 interface=sfp28-9
add bridge=bridge1 interface=sfp28-10
add bridge=bridge1 interface=sfp28-11
add bridge=bridge1 interface=sfp28-12
add interface=ether1 list=WAN
add interface=qsfp28-1-1 list=LAN
add interface=qsfp28-1-2 list=LAN
add interface=qsfp28-1-3 list=LAN
add interface=qsfp28-1-4 list=LAN
add interface=qsfp28-2-1 list=LAN
add interface=qsfp28-2-2 list=LAN
add interface=qsfp28-2-3 list=LAN
add interface=qsfp28-2-4 list=LAN
add interface=sfp28-1 list=LAN
add interface=sfp28-2 list=LAN
add interface=sfp28-3 list=LAN
add interface=sfp28-4 list=LAN
add interface=sfp28-5 list=LAN
add interface=sfp28-6 list=LAN
add interface=sfp28-7 list=LAN
add interface=sfp28-8 list=LAN
add interface=sfp28-9 list=LAN
add interface=sfp28-10 list=LAN
add interface=sfp28-11 list=LAN
add interface=sfp28-12 list=LAN
JimBouse
Re: No link when connecting CCR2216-1G-12XS-2XQ QSPF28 interfaces
Tue Oct 04, 2022 9:29 pm
Good afternoon.
I recently got our 2216 setup and am struggling to get our 100G interfaces to come up as well.
Did you ever get this working?
Thanks,
Jim
etdijarwanto
Fri Jan 06, 2023 8:50 am
Successfully connecting 40Gbps link on CCR2216-1G-12XS-2XQ to Nexus N6K using DAC 40G cable.
/interface/export
# jan/06/2023 14:40:51 by RouterOS 7.6
# software id =
# serial number =
set [ find default-name=qsfp28-1-1 ] auto-negotiation=no comment="SW-N6K-CORE #Port Eth2/1" l2mtu=9570 mtu=9570 speed=40Gbps
set [ find default-name=qsfp28-1-2 ] l2mtu=9570 mtu=9570 speed=40Gbps
set [ find default-name=qsfp28-1-3 ] l2mtu=9570 mtu=9570 speed=40Gbps
set [ find default-name=qsfp28-1-4 ] l2mtu=9570 mtu=9570 speed=40Gbps
!Command: show running-config interface Ethernet2/1
!Time: Fri Jan  6 14:44:03 2023
  description CCR2216-1G-12XS-2XQ#qsfp28-1
  switchport mode trunk
  duplex full
  no negotiate auto
Thank you,
Etdi J.
Users browsing this forum: sid5632 and 56 guests
