Matthiastik
basic ICMP rule
Wed Aug 17, 2022 5:47 am
Good evening,
I have problem that router rb4011ias having 2 lans, bridge and VoIP-Bridge at ip 192.168.100.1/24 and 192.168.0.1/24 and i have internet on both lan but
i can not ping my router but ping google etc on either lan with ip from respective bridge. i see that my router does not responde to ping from internet as well so secure but i think
ICMP/ping is vital to have a efficient network.
tried adding chain=input, protocol=icmp, accion=accept but lan ping still does not work, tried disable windows firewall but no succes not hits in firewall rule that i places as number 1.
basically what is the icmp rule that should make the router respond to icmp from any pc in any lan network ?
Thank you
tangent
Re: basic ICMP rule  [SOLVED]
Wed Aug 17, 2022 6:48 am
It pings out of the box, so you’ve configured the capability away somehow. Post your sanitized configuration here and we can help you debug it.
anav
Re: basic ICMP rule
Wed Aug 17, 2022 2:02 pm
I suspect your ISP provider is blocking ICMP on the WAN side but as stated, its all hot air, or letters until you post your config!
Matthiastik
Re: basic ICMP rule
Fri Aug 19, 2022 1:46 am
you where correct, had to fight with ISP before it started to work
tangent
Re: basic ICMP rule
Fri Aug 19, 2022 2:01 am
I don't see how you can blame the ISP when "lan ping still does not work," but success, I guess?
Matthiastik
Re: basic ICMP rule
Fri Apr 28, 2023 5:36 am
did a reset and programed again and you are probably right eventually but it works.
Thank you
Users browsing this forum: Gadulowaty, jasweb and 113 guests
