P00HB33R
Simple Queue Bandwidth Distribution
Wed Aug 17, 2022 8:49 am
Hi All,
I would like to get some clarity on simple queues.
So lets say I have created a Parent Simple Queue (PQ1) with 100Mbps Upload/100Mbps Download max limit allocated. Queue type is pcq-u/d/default.
Then I have 4 queues created with the parent queue set as PQ1.
Q1 = 100Mbps
Q2 = 50Mbps
Q3 = 25Mbps
Q4 = 10Mbps
If all 4 of these queues should try and max their download at the same time, how would bandwidth be distributed between these 4 queues?
What I am looking at getting answers for is, do I have to create a Parent queue for each speed tier, or would bandwidth be fairly distributed between different speed tiers done at the client queue level?
Thank you
P00HB33R
Re: Simple Queue Bandwidth Distribution
Tue Aug 30, 2022 9:18 am
Bumping this thread so someone can maybe help
LdB
Tue Aug 30, 2022 11:20 am
That one is in the manual and can't be answered
https://wiki.mikrotik.com/wiki/Manual:Q ... e_Examples
It must noted that if both limits (pcq-rate and max-limit) are unspecified, queue behavior can be imprecise. So it is strongly suggested to have at least one of these options set.
l suspect you want individual PCQ trees not one parent but hard to guess what you are trying to do.
Users browsing this forum: adwlodaro, Bruzxce, FAB1150 and 200 guests
