dmq
Dude on RouterOS 7.4.1 - Webserver missing
Wed Aug 17, 2022 12:45 pm
Dear community,
I installed The Dude 7.4.1 on a virtual routeros (proxmox). Since I am using Mac OS besides of Linux and there is no 64bit support, I really would like to access the MAP function inside the Webserver (or Winbox). The documentation (https://wiki.mikrotik.com/wiki/Manual:T ... r_settings) says that it should be able to configure a webserver in the Server Configuration Tab ob The Dude Client. I do not have that option. The documentation says "Port - port of the running web server. Might need to change if something else is running on port 80, or for security reasons. Note! if the Dude server is running on RouterOS, the port is 81 and can't be changed."
I do not have that port available:
Welcome back!
[admin@MikroTik] > /system/telnet 127.0.0.1 81
Connecting to 127.0.0.1
telnet: connect() failed: Connection refused
Port 80 works (WebFig etc.) - but there is no application under /dude.
What am I missing? Thank you very much in advance,
dmq
Sob
Re: Dude on RouterOS 7.4.1 - Webserver missing
Wed Aug 17, 2022 3:08 pm
Documentation also says:
This feature is not supported in The Dude v6.
dmq
Wed Aug 17, 2022 4:26 pm
Thanks. I saw this information. I thought it was just for version 6 and not the following releases.
But then it is clear - thanks again.
bpwl
Re: Dude on RouterOS 7.4.1 - Webserver missing  [SOLVED]
Wed Aug 17, 2022 5:14 pm
Release 6, DUDE management is with DUDE client, or is found in webfig or WinBox, under the DUDE submenu.
Webfig does have the MAP graphs (eg: http://.../webfig/#Dude:Network_Maps) , Winbox does not have the images. (Dude client has a dynamic MAP (reponds to mouse hover and clickable))
rextended
Wed Aug 17, 2022 5:23 pm
The "webpage" is no longer available on any v6 or v7 versions.
You must use Windows with corresponding dude client version, and you can see interactive graphic map.
dmq
Thu Aug 18, 2022 9:46 am
Thank you all. That helped me.
Users browsing this forum: No registered users and 20 guests
