gilljr
Issue with OSPF over a second link v7
Wed Aug 17, 2022 10:27 pm
I have a CCR2116-12G-4S+ running 7.4.1 and cannot establish a second link to another Mikrotik router running v6. The primary link is of network type ptp and is running fine reporting a state of Full. The second link (different interfaces over a different path) will only go into link state ExStart.
From the log of the v7 router
instance { version: 2 vrf: 0 router-id: x.x.x.216 } area { 2.2.2.2 } interface { instance-id: 1 p2p ether11 y.y.y.185 } created
instance { version: 2 vrf: 0 router-id: x.x.x.216 } area { 2.2.2.2 } interface { instance-id: 1 p2p ether11 y.y.y.185 } state change to Point-to-Point
instance { version: 2 vrf: 0 router-id: x.x.x.216 } area { 2.2.2.2 } interface { instance-id: 1 p2p ether11 y.y.y.185 } neighbor { router-id: x.x.x.119 state: Down } state change to Init
instance { version: 2 vrf: 0 router-id: x.x.x.216 } area { 2.2.2.2 } interface { instance-id: 1 p2p ether11 y.y.y.185 } neighbor { router-id: x.x.x.119 state: Init } state change to ExStart
I have done this multiple times with v6 to v6 connections with never an issue. Is this a bug or is there something I should be doing differently to establish the second link? This is my first router running v7 and it seems to operate differently.
gilljr
Re: Issue with OSPF over a second link v7
Sat Aug 27, 2022 1:36 am
Found the issue. Rookie mistake.
The microwave radio link was limiting mtu. I increased the mtu on the radio link and the OSPF came up.
connectlife
Sat Aug 27, 2022 11:12 am
Hi, thanks for your feedback
Users browsing this forum: No registered users and 64 guests
