bpbineesh
Multicast helper on Wifi wave2
Thu Aug 18, 2022 3:10 pm
please implement multicast helper feature on Wifiwave2 package
chechito
Re: Multicast helper on Wifi wave2
Thu Aug 18, 2022 4:31 pm
Just another thing that does not works on wave2.
A friendly reminder for anyone thinking to rush deploying hAP ax2.
dwnldr
Thu Nov 17, 2022 8:22 pm
Besides lot of troubles, also facing issues because of lacking multicast helper in wifiwave2...
FToms
Thu Apr 20, 2023 4:09 pm
Hello.
Could you please elaborate on what use case you require it for?
DarkNate
Mon Apr 24, 2023 9:32 pm
I think using IGMP Proxy (MLD Proxy) + IGMP (MLD) Snooping might help:
viewtopic.php?p=993957&hilit=mdns+repeater#p982910
UpRunTech
Wed Apr 26, 2023 3:23 am
I think he's talking about the multicast helper which is in the Wireless (and CAPSMAN) system which does multicast to unicast conversion at the radio interface. It's needed to make things like mDNS and DHCP more reliable and also allow for use of VLANs with wireless clients. I am surprised it doesn't exist in WifiWave2.
Search for it in https://help.mikrotik.com/docs/display/ ... +Interface
So yeah, FTOMs what's the go with multicast to unicast conversion in WifiWave2? Does it exist in some other form?
mman1982
Tue Apr 02, 2024 3:06 pm
Currently searching for the same! Has anyone found something about it?
infabo
Forum Veteran
Forum Veteran
Tue Apr 02, 2024 3:11 pm
After tough and hard CTRL+F search quest I found this:
"multicast-enhance (enabled | disabled)
With the multicast-enhance feature enabled, an AP will convert every multicast-addressed IP or IPv6 packet into multiple unicast-addressed frames for each connected station.
This may improve link throughput and reliability since, unlike multicast frames, unicasts are acknowledged by stations and transmitted using a higher data rate.
Default: disabled"
https://help.mikrotik.com/docs/display/ ... 20disabled
mman1982
Tue Apr 02, 2024 3:13 pm
Tried,but my tv box worked with multicast helper full,and not working with that.
infabo
Forum Veteran
Forum Veteran
Tue Apr 02, 2024 4:16 pm
- wireless driver: "multicast-helper: When set to full, multicast packets will be sent with a unicast destination MAC address, resolving multicast problem on the wireless link." https://help.mikrotik.com/docs/display/ ... +Interface
- wifi driver: "multicast-enhance: With the multicast-enhance feature enabled, an AP will convert every multicast-addressed IP or IPv6 packet into multiple unicast-addressed frames for each connected station." https://help.mikrotik.com/docs/display/ROS/WiFi
Layer 2 is implied as they use the keyword "frame" in the multicast-enhance description. And they imply layer 3 (IP) as they use "packet" in multicast-helper description. So according to the docs it should IMHO do the same.
mman1982
Tue Apr 02, 2024 5:08 pm
Thank you for help,i will play with settings.
Users browsing this forum: timotei and 27 guests
