kiloon
LTE device disonnecting
Thu Aug 18, 2022 8:03 pm
Hello dear friends. Here is my subject: LTE device has disconnecting some times and I am loosing internet connection.
Solution is to disconnect USB power for 5 seconds (system/routerboard/usb/power-reset duration=4)
So i would like to automate this as a script. When LTE device not searching for network it will run this script.
Any help will be very appreciated!
eldoncito2019
Re: LTE device disonnecting
Fri Aug 19, 2022 1:55 pm
:if ([/ping 8.8.8.8 count=5] = 0) do={/system reboot}
EL DONCITO.
BillyVan
Re: LTE device disonnecting  [SOLVED]
Fri Aug 19, 2022 2:17 pm
Give a try on Schedule interval time 00.01.00
:if ([/ping address=8.8.8.8 count=5 interface=lte1 size=50]=0) do={
:log error "LTE DOWN";
/interface disable lte1
/delay 1s
/interface enable lte1}
rextended
Fri Aug 19, 2022 2:23 pm
«only 1 minute between try» = «continuosly activation and reactivation of lte»
Jotne
Fri Aug 19, 2022 4:43 pm
kiloon
Sat Aug 20, 2022 1:44 pm
Thank you guys so much for answering! I would definitely use Netwatch but my first question is what should i write In the field that is named "Host"
Do i have to put ip address of this device? (let say it does have 192.168.8.1)
My understanding is that if the host is "down" in the Down field i should put my script.
Sorry for being newbie =) but i am learning.
Jotne
Sat Aug 20, 2022 8:32 pm
See script here: viewtopic.php?p=888800#p888800
It can be changed to use email/pushbullet etc to send information.
Users browsing this forum: No registered users and 36 guests
