rextended
Re: Mikrotik hAP ac2 connection issues + doesn't show up in netinstall
Fri Aug 19, 2022 10:01 am
use netinstall, search on forum and read the guides for how to use netinstall
AidanAus
Tue Sep 06, 2022 4:59 am
one of the main things I have found with netinstall is that it needs 100% transparent layer 2 communication with the device you are trying to install, this means that if you have any virtual adaptors or switch's etc on the pc from things like a WSL or hyperv installation that you would need to temporarily disable these adapters while performing the netinstall.
holvoetn
Tue Sep 06, 2022 7:09 am
Apart from the suggestion to disable ALL physical and virtual interfaces except for that one ethernet port, putting a dumb switch in between or using Linux may help as well (I have 100% success using Linux, Windows more like 10-20%).
Users browsing this forum: No registered users and 37 guests
