spippan
Wireguard Performance and HW-Offload
Fri Aug 19, 2022 5:43 pm
how does rOS process WG processes/connections/peers?
i am aware, it is 100% done in CPU but does a routerboard/CCR with IPsec hw-offload (similar to AES-NI on x86) leverage wireguard connections with such features?
for example, i have 2 hEX-S on a L2 backbone directly connected. they form a WG peering-pair and via that connection there is a VXLAN configured, which works fine. the L2 line i am delivered by a local fibre provider is a 100mbit line.
i just need to know how wireguard is processed. how is it scalable for connectiones more than 100mbit?
as i have set this up in a LAB-environment i got ~200mbit via the vxlan connection (which runs ontop of the wireguard tunnel)
reason for the question also is, for example, a RB1100x4 has some pretty nice IPsec Test Results due to the abillity to hw-offload AES!
Znevna
Re: Wireguard Performance and HW-Offload
Fri Aug 19, 2022 6:11 pm
Answered multiple times in this forum:
No.
spippan
Fri Aug 19, 2022 6:20 pm
No.
i searched for that answer .... where? can you point one or two links?
anav
Fri Aug 19, 2022 6:26 pm
Znevna
Fri Aug 19, 2022 7:00 pm
No.
Sure, I'll search for you:
viewtopic.php?p=925191#p925191
viewtopic.php?p=906426#p906426 (at least two posts in this topic stating the same thing).
viewtopic.php?p=868363#p868363
viewtopic.php?p=867574#p867574
viewtopic.php?p=762075#p762075
rextended
Fri Aug 19, 2022 7:49 pm
useless topic is useless...
(not so covertly referred to viewtopic.php?p=952643#p952643)
spippan
Fri Aug 19, 2022 8:17 pm
thanks for the clarification
spippan
Fri Aug 19, 2022 8:19 pm
is it?
Users browsing this forum: Amazon [Bot], Bing [Bot], dazzaling69, Question, volneymota and 132 guests
