Andrew162
Polish Netia Internet Fiber - slow internet on mikrotik
Fri Aug 19, 2022 7:42 pm
Hello
Im from Poland and got Mikrotik RB3011UiAS-RM as a Core switch
arround 7 month ago after update ( not sure what version )
My internet slow down from 1Gb to max 200Mb and cant go faster even more then 1bit
Internet is Netia Poland Fiber
After 6 month of talking with ISP Netia ... today i was talk with enginer network of Netia
Who try push me.. that its my fault
And i try push him that they change somethink 7 months ago
Explanation :
On they Router internet is 1Gb
On they modem( converter fiber to eth) directly to pc got 1Gb
On they modem -> Mikrotik > PC = 200Mb
On they Router in bridge mode -> mikrotik -> pc 200Mb
The Guy said i should check MTU and some jumbo ..
Im not so advance in mikrotik.
But still.. he didnt send me or say any extra settings to that PPPoE connection..
Please help
BartoszP
Re: Polish Netia Internet Fiber - slow internet on mikrotik
Fri Aug 19, 2022 10:11 pm
Send sanitized config please.
Andrew162
Fri Aug 19, 2022 10:15 pm
I make Clean "default" config
fill Quick set and set pppoe
And work 1gb
After 1h ..
i try to copy firewalls ports.. scripts.. but it was too many
i Copy clean working 1gb config .rsc
use backup to previus
And paste
And its work.
Topic close
But im anyway curious what was STOPPING internet..
Znevna
Sat Aug 20, 2022 7:46 am
Your secret config, obviously.
Andrew162
Fri Sep 16, 2022 7:30 pm
Hello
The problem came back.
Now only the "super clean" config with very basic settings like bridge ,login password pppoe and masquarada...
make my internet 1Gb
I try screen shot some pppoe settings.. check HW..
Even copy all Firewall rules and nat to "clean config" and internet look still ok
Advice please
rextended
Fri Sep 16, 2022 7:34 pm
You are really annoying, several times you have been asked from other users to see the configuration, not to read any novels from you.
Andrew162
Fri Sep 16, 2022 7:37 pm
Can you please remind me how to print config with password *
I know there is a command.. and i will "working" and "my config" (Found it)
Andrew162
Fri Sep 16, 2022 7:45 pm
SLOW - with all my firewalls etc what i need
# sep/16/2022 18:43:01 by RouterOS 7.6beta6
# software id = 5QPU-AP8A
# model = RB3011UiAS
# serial number = <CENSORED>
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=Tikimyki
/system package update
set channel=development
/system scheduler
add comment=p0p.ddns.net disabled=yes interval=30s name=NO-IP on-event=\
    p0p.ddns.net policy=read,write,test start-date=apr/21/2021 start-time=\
    09:46:44
add comment=andomor.ddns.net disabled=yes interval=35s name=NO-IP on-event=\
    andomor.ddns.net policy=read,write,policy,test start-time=startup
add comment=ALLDDNS disabled=yes interval=10m name=NO-IP on-event=ALLDDNS \
    policy=read,write,test start-time=startup
add name=startup-beep on-event="Startup: Super Mario Bros" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=\
    startup
/system script
add dont-require-permissions=no name=andomor.ddns.net owner=admin policy=\
    read,write,test source="# No-IP automatic Dynamic DNS update\r\
    \n\r\
    \n#--------------- Change Values in this section to match your setup -----\
    -------------\r\
    \n\r\
    \n# No-IP User account info\r\
    \n:local noipuser \"<CENSORED>\"\r\
    \n:local noippass \"<CENSORED>\"\r\
    \n\r\
    \n# Set the hostname or label of network to be updated.\r\
    \n# Hostnames with spaces are unsupported. Replace the value in the quotat\
    ions below with your host names.\r\
    \n# To specify multiple hosts, separate them with commas.\r\
    \n:local noiphost \"<CENSORED>.ddns.net\"\r\
    \n\r\
    \n# Change to the name of interface that gets the dynamic IP address\r\
    \n:local inetinterface \"pppoe-out2\"\r\
    \n\r\
    \n#-----------------------------------------------------------------------\
    -------------\r\
    \n# No more changes need\r\
    \n\r\
    \n:global previousIP\r\
    \n\r\
    \n:if ([/interface get \$inetinterface value-name=running]) do={\r\
    \n# Get the current IP on the interface\r\
    \n   :local currentIP [/ip address get [find interface=\"\$inetinterface\"\
    \_disabled=no] address]\r\
    \n\r\
    \n# Strip the net mask off the IP address\r\
    \n   :for i from=( [:len \$currentIP] - 1) to=0 do={\r\
    \n       :if ( [:pick \$currentIP \$i] = \"/\") do={ \r\
    \n           :set currentIP [:pick \$currentIP 0 \$i]\r\
    \n       } \r\
    \n   }\r\
    \n\r\
    \n   :if (\$currentIP != \$previousIP) do={\r\
    \n       :log info \"No-IP: Current IP \$currentIP is not equal to previou\
    s IP, update needed\"\r\
    \n       :set previousIP \$currentIP\r\
    \n\r\
    \n# The update URL. Note the \"\\3F\" is hex for question mark (\?). Requi\
    red since \? is a special character in commands.\r\
    \n       :local url \"http://dynupdate.no-ip.com/nic/update\\3Fmyip=\$curr\
    entIP\"\r\
    \n       :local noiphostarray\r\
    \n       :set noiphostarray [:toarray \$noiphost]\r\
    \n       :foreach host in=\$noiphostarray do={\r\
    \n           :log info \"No-IP: Sending update for \$host\"\r\
    \n           /tool fetch url=(\$url . \"&hostname=\$host\") user=\$noipuse\
    r password=\$noippass mode=http dst-path=(\"no-ip_ddns_update-\" . \$host \
    . \".txt\")\r\
    \n           :log info \"No-IP: Host \$host updated on No-IP with IP \$cur\
    rentIP\"\r\
    \n       }\r\
    \n   }  else={\r\
    \n       :log info \"No-IP: Previous IP \$previousIP is equal to current I\
    P, no update needed\"\r\
    \n   }\r\
    \n} else={\r\
    \n   :log info \"No-IP: \$inetinterface is not currently running, so there\
    fore will not update.\"\r\
    \n}"
add dont-require-permissions=no name=owncloud owner=adminnt policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="s\
    udo nano /etc/lighttpd/lighttpd.conf\r\
    \n\r\
    \nsudo nano /var/www/owncloud/config/config.php\r\
    \n\r\
    \n/system ssh 192.168.1.31 user=<CENSORED>\r\
    \n<CENSORED>\r\
    \nhttps://www.avoiderrors.com/install-owncloud-on-raspberry-pi-4-2/\r\
    \nSetup USB HDD to owncloud\r\
    \n\r\
    \n\r\
    \n######overclock debian#########\r\
    \nsudo nano /boot/config.txt \r\
    \n#napiecie\r\
    \nover_voltage=-2\r\
    \n#max arm\r\
    \narm_freq=1500\r\
    \n#minimum arm\r\
    \ncore_freq=500\r\
    \ngpu-freq=600\r\
    \n\r\
    \narm_freq=2200\r\
    \ngpu_freq=750\r\
    \nover_voltage=6\r\
    \n\r\
    \n###################\r\
    \novervoltage ubuntu\r\
    \n\r\
    \nsudo nano /boot/firmware/config.txt\r\
    \nsudo nano /boot/config.txt\r\
    \n\r\
    \n\r\
    \n##########check linux version########\r\
    \ncat /etc/*release\r\
    \n#######################OMV\r\
    \n/system ssh 192.168.1.10 user=<CENSORED>\r\
    \n\r\
    \npass <CENSORED>\r\
    \n########################\r\
    \n\r\
    \n\r\
    \n\r\
    \n/var/www/lighttpd.html\r\
    \nstrona glowna \r\
    \n\r\
    \nsudo su - strona glowna powrot"
add dont-require-permissions=no name=igor owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="H\
    ello Igor\r\
    \nHello Hermanto\r\
    \n\r\
    \nIm a tester gaming/software in Aster with many year experience\r\
    \n\r\
    \nBefore start typing about games. Some hardware requirements need to be a\
    complish depend of pc power (what license for computer/how many workstatio\
    n per PC) like USB HUB with Active power(for many workstation recomend usb\
    3.0), USB music cards\r\
    \nThe entire proces of configuring the Aster its simple like drag and drop\
    \_device to each workstation.\r\
    \nGaming.\r\
    \nFor counter stike GO -\r\
    \nhttps://www.youtube.com/watch\?v=KAGogEKn_pg\r\
    \nIts a non steam version\r\
    \nAfter correct config IP in aster which we can provide tutorial how its e\
    xactly need to be done step by step\r\
    \nYou can easily play this game on the maximum number of workstations we p\
    rovide which is 12\r\
    \nFor each workstation, I recommend 2 processor cores that can be set rigi\
    dly in Aster + SSD + GTX1080ti \r\
    \nWe cant provide exactly parametrs of computer becaouse each game provide\
    \_diffrent requirements and its depend how many Workstation will you put t\
    o each computer.\r\
    \nSo the limit of \"how many games we can launch on Aster\" its only depen\
    d how powerfull PC we got\r\
    \n\r\
    \nIn some cases we can also install game again on diffrent SSD/HDD so for \
    example 4 user Run the game from C drive SSD other 4 from D SSD - if we wa\
    nt to load games quickly and smoothly, with a large number of users.\r\
    \nPlease keep in mind that when computer launch second (for example ) Coun\
    ter strike its not \"eat\" x2 resources of PC, but arround x0.2 - x0.8 usu\
    ally its arround x0.5 becaouse no need run DLL some files twice etc.\r\
    \nFor example if we got in Counter strike 100FPS\r\
    \nand we run second Counter strike . Both users will experience arround 80\
    -90FPS /not half \r\
    \n\r\
    \nOfcors i will test all that games for you Hermanto for give you idea how\
    \_its will perform.\r\
    \nI'm also on the support team where I mainly do game support , so after t\
    he purchase, our support does not end, but vice versa. I'm always here to \
    help you.\r\
    \nI will test other games and send you results until monday.\r\
    \n\r\
    \nRegards\r\
    \nAndrzej Lachowicz\r\
    \n\r\
    \n\r\
    \n"
add dont-require-permissions=no name=Pinecraft owner=adminnt policy=test \
    source="pi\r\
    \nB...."
add dont-require-permissions=no name="Music: Super Mario Bros" owner=admin \
    policy=read source=":beep frequency=660 length=100ms;\
    \n:delay 150ms;\
    \n:beep frequency=660 length=100ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:beep frequency=510 length=100ms;\
    \n:delay 100ms;\
    \n:delay 300ms;\
    \n:beep frequency=770 length=100ms;\
    \n:delay 550ms;\
    \n:beep frequency=380 length=100ms;"
add dont-require-permissions=no name="Music: Thunderstruck" owner=admin \
    policy=read source=":local n11 63,66;\
    \n:local n12 64,67;\
    \n:local n21 71,69,68,69,68,66,68,64,66,63;\
    \n:local n22 64,63;\
    \n\
    \n:local n11 (\$n11,\$n11);\
    \n:local n12 (\$n12,\$n12);\
    \n:local n1 (\$n11,\$n11,\$n12,\$n12);\
    \n:local n2 (\$n21,\$n22,\$n22,\$n22);\
    \n:local notes (\$n1,\$n1,\$n2,\$n2);\
    \n  \
    \n:local ticks 2;\
    \n:local speed 55ms;\
    \n:local stacc 5ms;\
    \n# Transposition\
    \n:local transpose -48;\
    \n# ==============================\
    \n# Don't change this:\
    \n:local frqtab 8372,8869,9397,9956,10548,11175,11839,12543,13288,14080,14\
    916,15804;\
    \n:local n0; :local n;\
    \n:local d0; :local d;\
    \n:local l;\
    \n:local midi;\
    \n:local i;\
    \n:local octa;\
    \n:local frq;\
    \n:for i from=0 to= ([:len \$notes]-1) do={\
    \n:set midi [:pick \$notes \$i];\
    \n:set midi (\$midi + \$transpose);\
    \n:set octa 0;\
    \n:while ( \$midi < 60) do={:set midi (\$midi + 12); :set octa (\$octa + 1\
    \_  ); };\
    \n:set midi (\$midi - (12 * (\$midi /12)));\
    \n:set frq [:tonum [:pick \$frqtab \$midi]];\
    \n:set frq (\$frq>>(\$octa));\
    \n:set d0 \$ticks;\
    \n:set d (\$d0 * \$speed );\
    \n:set l (\$d0 * (\$speed - \$stacc));\
    \n:beep fr=\$frq le=\$l;\
    \n:delay \$d;\
    \n:set midi 59;\
    \n:set octa 0;\
    \_  ); };\
    \n:set d0 \$ticks;\
    \n:delay \$d;\
    \n}"
add dont-require-permissions=no name="Startup: Super Mario Bros" owner=admin \
    policy=read source=\
    "delay 5;\
    \n/system script run \"Music: Super Mario Bros\";"
add dont-require-permissions=no name="Music: Imperial March  (Star Wars)" \
    owner=admin policy=read source=":beep frequency=500 length=500ms;\
    \n:delay 500ms;\
    \n:beep frequency=500 length=500ms;\
    \n:delay 500ms;\
    \n:delay 500ms;\
    \n:beep frequency=400 length=500ms;\
    \n:delay 400ms;\
    \n:beep frequency=600 length=200ms;\
    \n:delay 100ms;\
    \n:delay 500ms;\
    \n:delay 400ms;\
    \n:delay 100ms;\
    \n:delay 1000ms;\
    \n:beep frequency=750 length=500ms;\
    \n:delay 500ms;\
    \n:delay 500ms;\
    \n:delay 500ms;\
    \n:beep frequency=810 length=500ms;\
    \n:delay 400ms;\
    \n:delay 100ms;\
    \n:beep frequency=470 length=500ms;\
    \n:delay 500ms;\
    \n:delay 400ms;\
    \n:delay 100ms;\
    \n:delay 1000ms;"
add dont-require-permissions=no name="Music: Jurassic Park" owner=admin \
    policy=read source=":beep frequency=466 length=275ms;\
    \n:delay 300ms;\
    \n:beep frequency=440 length=275ms;\
    \n:delay 300ms;\
    \n:beep frequency=466 length=1775ms;\
    \n:delay 1800ms;\
    \n:beep frequency=466 length=275ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:delay 1800ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:beep frequency=466 length=875ms;\
    \n:delay 900ms;\
    \n:beep frequency=523 length=275ms;\
    \n:delay 300ms;\
    \n:beep frequency=523 length=875ms;\
    \n:delay 900ms;\
    \n:beep frequency=622 length=275ms;\
    \n:delay 300ms;\
    \n:beep frequency=622 length=1775ms;\
    \n:delay 1800ms;\
    \n:beep frequency=587 length=275ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:delay 900ms;\
    \n:delay 300ms;\
    \n:beep frequency=349 length=575ms;\
    \n:delay 600ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:beep frequency=523 length=1775ms;\
    \n:delay 1800ms;\
    \n:beep frequency=698 length=275ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:beep frequency=622 length=875ms;\
    \n:delay 900ms;\
    \n:delay 300ms;\
    \n:beep frequency=587 length=875ms;\
    \n:delay 900ms;\
    \n:delay 300ms;\
    \n:beep frequency=523 length=3575ms;\
    \n:delay 3600ms;\
    \n:delay 600ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:beep frequency=466 length=575ms;\
    \n:delay 600ms;\
    \n:delay 600ms;\
    \n:beep frequency=311 length=575ms;\
    \n:delay 600ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:delay 600ms;\
    \n:delay 600ms;\
    \n:delay 600ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:delay 300ms;\
    \n:delay 900ms;\
    \n:beep frequency=349 length=575ms;"
add dont-require-permissions=no name="Music: Crazy Train" owner=admin policy=\
    read source=":beep frequency=370 length=175ms;\
    \n:delay 200ms;\
    \n:beep frequency=370 length=175ms;\
    \n:delay 200ms;\
    \n:delay 1200ms;\
    \n:beep frequency=440 length=175ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 400ms;\
    \n:beep frequency=330 length=175ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 400ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 1200ms;\
    \n:beep frequency=587 length=175ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 400ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 400ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:beep frequency=554 length=175ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:beep frequency=494 length=175ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:beep frequency=415 length=175ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:delay 200ms;\
    \n:beep frequency=587 length=775ms;\
    \n:delay 800ms;\
    \n:beep frequency=330 length=775ms;\
    \n:delay 800ms;"
add dont-require-permissions=no name="Startup: Crazy Train" owner=admin \
    policy=read source="delay 5;\
    \n/system script run \"Music: Crazy Train\";"
add dont-require-permissions=no name="Startup: Thunderstruck" owner=admin \
    "delay 5;\
    \n/system script run \"Music: Thunderstruck\";"
add dont-require-permissions=no name="Startup: Imperial March" owner=admin \
    "delay 5;\
    \n/system script run \"Music: Imperial March  (Star Wars)\";"
add dont-require-permissions=no name="Startup: Jurassic Park" owner=admin \
    "delay 5;\
    \n/system script run \"Music: Jurassic Park\";"
CLEAN work 1Gb
# aug/19/2022 21:08:25 by RouterOS 7.5beta5
add admin-mac=08:55:31:A1:1D:5A auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    use-peer-dns=yes user=<CENSORED>
/disk
set usb1 disabled=no
set usb1-part1 disabled=no name=disk1
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=MykiTiki
add name=dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.26 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/tool mac-server
/tool mac-server mac-winbox
Reason: <CENSORED> all private data I see...
rextended
Fri Sep 16, 2022 7:57 pm
I just censore dozen of private data with <CENSORED> inside your post, check twice if something is left....
Andrew162
Fri Sep 16, 2022 7:59 pm
user=<CENSORED>
is a my login and password to my PPPOE
"system export hide-sensitive file=slow"
So password etc are hidden .
rextended
Fri Sep 16, 2022 8:04 pm
If the problem came back when you install 7.6beta, revert to 7.5, and on your "slow" configuration, are present only scripts, no firewall rules or other relevant things.
rextended
Fri Sep 16, 2022 8:06 pm
user=<CENSORED>
    \n\r\
Enough, for me you are too grumpy, make do with others, if they help you.
Andrew162
Fri Sep 16, 2022 8:14 pm
On 7.6 and 7.5 same issue
But i back to 7.5 to be 100% sure and same situation
I also disable manualy
L2TP server
DUDE server
Containers
change DNS for DHCP from pihole local raspi4 to 1.1.1.1 and 8.8.8.8
Mach the Routes with "working settings"
Speed the same
Andrew162
Fri Sep 16, 2022 8:16 pm
I disable all Scripts and schedules.
So no need check that "code"
Andrew162
Fri Sep 16, 2022 8:22 pm
I'm sorry if my statements / answers are not very logical for you, but I know little about mikrotik. Even though my code says otherwise. But it's taken many weeks of work / reading, watching and testing to get all I have to work in it.
Andrew162
Fri Sep 16, 2022 9:08 pm
After add'ing and enabling that policy
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \
Internet back to 90-95% of "should be" speed
CPU 75%
Its could meen i need faster mikrotik i guess
Users browsing this forum: fhuladaq, fqx, sailren and 111 guests
