With the current Version of WinBox (3.37) in the IPV6 Firewall NAT window, if you use the NETMAP Action the "to-address" field is missing. But you have to use it if you want to create this entry.
If you create this rule with the Command Line the NETMAP is not working.
Is this a known issue? When will this be fixed?
