jn050375
CPU load
Sun Aug 21, 2022 12:37 pm
Good morning,
I would like to ask you, RB practitioners, a question about the CPU load. I have several RB3011, CRS328, CRS125 machines and a dozen or so hAPmini and hAPac3 machines. Virtually every machine shows a high CPU load. These are jumps of about 50ms. I am enclosing a video.
Importantly, the so-called sudden jumps are present all the time, that is, both when the device is loaded with movement and when it is not loaded with the movement of the hardware.
I have already tried downgrade and upgrade and it doesn't change much.
Can you guide me in what direction I should look for causes?
Regards
mkx
Re: CPU load
Sun Aug 21, 2022 1:59 pm
Do CPU liad spikes happen also when winbox isn't connected to tgem? It is known that winbox (in particular: frequent updates of shown statuses and counters) causes quite some CPU load, in some particular cases even critically high CPU load.
DanMos79
Re: CPU load
Sun Aug 21, 2022 2:12 pm
The green bar is not an indicator of CPU usage, but an indicator of traffic between RouterOS and WinBox.
https://help.mikrotik.com/docs/display/ ... ceOverview
Users browsing this forum: ulds and 90 guests
