is there a proper way to differentiate between RouterOS v6.x and v7.x in a configuration script?
I tried
Code: Select all
/system resource
:global versionStr [get value-name=version]
:if ([:pick $versionStr 0] < 7) do={
/log info "Found RouterOS v6.x."
/system ntp client
set enabled=yes primary-ntp=192.168.144.210
} else={
/log info "Found RouterOS v7.x."
/system ntp client
set enabled=yes servers=192.168.144.210
/system ntp server
set enabled=yes
Code: Select all
primary-ntp
Code: Select all
expected end of command (line 4 column 19)
Daniel
