solar77
Long time Member
Long time Member
possible to join Virtual AP to CapsMan, without its master wireless Interface?
Mon Aug 22, 2022 2:33 pm
I am trying to create virtual AP, and to be managed by capsman, while keep physical interface wlan1 and wlan2 as it is. Would this possible?
It's on Mikroitk hAP AC2. so far I've not managed to do it.
PS: Capsman config is correct and I have mutiple Mikrotik CAP AC devices managed by it.
holvoetn
Re: possible to join Virtual AP to CapsMan, without its master wireless Interface?
Mon Aug 22, 2022 6:14 pm
I doubt you can use the virtual without the master interface being part of capsman.
Even disabling master will instantly disable slave connected to it as well.
whatever
Mon Aug 22, 2022 7:54 pm
This is not possible, you hand over control to capsman on a per-(physical-)interface basis.
Users browsing this forum: freemannnn, jaclaz, vic666 and 35 guests
