tysongoulding
Dot1x script to enable/disable interfaces
Tue Aug 23, 2022 6:58 pm
Hello all,
Would like a script that can disable/enable the server interface based on the active vlan.
Version 7.2.3
For example:
server interface ether2 has a vlan of 2200
server interface ether3 has a vlan of 2200
server interface ether5 has a vlan of 200
Want to be able to disable ether2/ether3 based on vlan2200
Believe I need a :foreach command to make this work.
Need to get the interface from:
/interface/dotx1x/server/active print where vlan-id-2200
Use interface above to disable:
/interface/dot1x/server print
Idea CLI
interface dot1x server disable [/interface dot1x server active find vlan-id=2200]
interface dot1x server enable [/interface dot1x server find where disabled] working
Output Samples:
Thanks in advanced!
tysongoulding
Re: Dot1x script to enable/disable interfaces
Wed Aug 24, 2022 4:53 pm
/interface/dot1x/server/active
:foreach i in=[find where vlan-id=2200] do={
:local int [get $i interface]
/interface/dot1x/server disable interface=$int
Found another issue, not able to disable interface, can only disable numbers
:foreach a in=[print where vlan-id=2200] do={
:local int [get $a interface]
:foreach b in=[find where interface=$int] do={
:local n [get $b number]
/interface dot1x server disable number=$n
Do not know how to combine these, even if these work
Users browsing this forum: JDF, patrikg, rextended and 27 guests
