mikmanager04
get comment array save to table
Tue Aug 23, 2022 9:51 pm
can anyone help im i want export the price and package to table without th
comment value format
,3,30 Minutes,5,1 Hour,10,2 Hours,20,3 Hours,30,5 Hours,40,1 Day,50,2 Days,60,3 Days,90,7 Days,150,15 Days,300,30 Days
:global RATE [/routing filter get [find chain=RATE] comment];
/file set flash/hotspot/rate.js contents= \
"document.getElementById('myTable').innerHTML='$RATE';"
:log info ("Rate Set");
iwant rate.js output like this
<tr><td>3</td><td>30 Minutes</td></tr>
rextended
Re: get comment array save to table
Tue Aug 23, 2022 9:57 pm
You can add screenshot or picture with "Attachments" section when you add a post on a topic.
Do not use 3rd party sites (for monetiziong or not) for host images.
mikmanager04
Tue Aug 23, 2022 10:23 pm
found it , thank you
final output i want load the the file insert to table like this
mikmanager04
Wed Aug 24, 2022 11:40 am
i change the get comment 90% finish now my last problem is combine the txt first tr & td and last closing td & tr tag like this
:global contentz [/routing filter get [find chain=packageList] comment];
:global content [:pick $contentz 1 [:len $contentz]];
:set content ("$content" . "" . "|");
:global contentLen [ :len $content ] ;
:global lineEnd 0;
:global line "";
:global lastEnd 0;
:do {
       :set lineEnd [:find $content "|" $lastEnd ] ;
       :set line [:pick $content $lastEnd $lineEnd] ;
       :set lastEnd ( $lineEnd + 1) ;
       :local tmpArray [:toarray $line] ;
	:if ( [:pick $tmpArray 0] != "" ) do={
	:put $tmpArray;
/ppp secret add name=[:pick $tmpArray 3] comment=[:pick $tmpArray 0];
} while ($lineEnd < $contentLen)
Users browsing this forum: No registered users and 33 guests
