DeonBitz
SMB over Mikrotik VPN
Wed Aug 24, 2022 2:46 pm
Good day all
I am very new to Mikrotik so please help.
I have a TrueNAS server with SMB share. I want to be able to access that share from another site using the Mikrotik VPN. How do I go about setting it up?
Thank you
Sob
Re: SMB over Mikrotik VPN
Wed Aug 24, 2022 11:56 pm
Start with providing more details. How's ability to accept incoming connections from internet for each site (public address yes/no, static/dynamic), router models, RouterOS versions, ...
BartoszP
Thu Aug 25, 2022 8:27 am
Without or without that information the answer is quite simple:
1. set any vpn between sites.
2. set the MTU & clamp MSS to same size on both ends of VPN
3. check if you can ping devices from both sides with small and huge packets.
4. Start using SMB.
Users browsing this forum: gabbot, llamajaja, ryancccc and 29 guests
