Rustie0125
Mikrotik Knot LR9 LTE-M not reliable
Wed Aug 24, 2022 3:04 pm
Hey
I recently started testing the Knot LR9 vs the Ltap device with LR9 card. and I'm having very unstable connection. Just wondering if someone else has experiences the same ?
I'm 80% is network related but I have no way or at least I don't know of a way to check signal strength on the signal as the only script I found to print these values out in the terminal requires the modem to be disconnected/disabled and since I'm logging in via this modem( when available) its an issue.
most of the info I used comes from this post
viewtopic.php?t=176650
Rustie0125
Re: Mikrotik Knot RB924iR-2nD-BT5&BG77 LR9 LTE-M not reliable
Thu Aug 25, 2022 8:51 pm
Device with LR9 radio. running 7.4.1 will start up and connect to LTE-M network as expected but goes offline 24 hours later and does not auto reconnect. the LTE light stays connected but Lora data is not passed on and I cannot “see” the router remotely. repeated the test 3 times keeps failing 24 hour later
denissMT
Re: Mikrotik Knot LR9 LTE-M not reliable
Wed Sep 07, 2022 11:33 am
Please create a support ticket:
https://mikrotik.com/support
Users browsing this forum: No registered users and 71 guests
