danklod
Simple script for set pref-source
Wed Aug 24, 2022 3:13 pm
I'm trying to set pref-source on specific route on multiple device with the LAN address on each one router but I have problem. When I'm trying with this script nothing it happen.
For example I have:
add address=10.0.5.1/24 comment="default configuration" interface=LAN network=10.0.5.0
add distance=1 dst-address=10.120.0.0/16 gateway=10.10.10.1
:local langw1 [/ip address get [find interface="LAN"] address];
:local perfsrc1 [/ip route get [find dst-address=10.120.0.0/16 pref-src];
:if ($langw1 != $perfsrc1) do={
/ip route set pref-src=$langw1 [find dst-address=10.120.0.0/16];
I want to set 10.0.5.1 for "pref-src" but as variable value because on each one router this value will be different.
Can you help me with this?
Thank you!
rextended
Re: Simple script for set pref-source
Wed Aug 24, 2022 8:15 pm
when you get the address, you get also the subnet mask /xx
pref-src do not have subnet mask and you can not use ip with subnet mask on set
you can not compare two values like ("127.0.0.1" = "127.0.0.1/24")
remove the subnet mask with :pick before use the address as pref-src and before use it on compare
danklod
Thu Aug 25, 2022 10:14 am
Thank you!
I changed it with this, because for first time I use scripts and don't know how to use :pick yet, but I still have problem:
:local langw1 [/ip dhcp-server network get value-name=gateway number=0];
:local perfsrc1 [/ip route get [find dst-address=10.120.0.0/16] pref-src];
or
:if ($perfsrc1 = 0.0.0.0) do={
/ip route set [find dst-address=10.120.0.0/16] pref-src=$langw1;
on all routers I have only one dhcp server for LAN network (for example gateway is set 10.0.5.1)
Users browsing this forum: No registered users and 36 guests
