dnielr
Chateau LTE admin panel cannot be reached even after Factory reset
Thu Aug 25, 2022 12:59 pm
Hello
Router:
Chateau LTE v7.04
Setup environment:
Mikrotik Android app v1.3.27 / Lubuntu 22.04 LTS
I was able to configure the router through Wifi with Quick or Manual setup
but after I have set up a Wifi connection I was not able to reach admin panel from any device.
Factory reset (repower and hold reset button for 5 seconds) resolved the issue and I was able to start try again.
Customer support suggested me to use the following guide for first installation:
https://help.mikrotik.com/docs/display/ ... figuration
Menu looked different and I was only able to do first step:
Open Bridge window, Bridge tab should be selected;
Click on the + button, a new dialog will open, enter bridge name local and click on OK;
Since then I cannot reach admin panel from Wifi even after mentioned factory reset.
I tried to remove device from internet and configure it throught ethernet connection offline but I still cannot reach admin panel.
Please advise how can I resolve this issue as the product is not usable at this state.
Note: Currently I cannot connect to internet through ethernet with a PC.
Many thanks!
Kind regards,
Daniel
dnielr
Re: Chateau LTE admin panel cannot be reached even after Factory reset
Thu Aug 25, 2022 6:41 pm
I was able to connect modem+router+ethernet and after a scan I was able to reach router on another local IP address.
Guide has been followed until:
"Now when the security profile is ready we can enable the wireless interface and set the desired parameters"
I cannot set wlan available due following message:
Couldn't change Interface <wlan1> - interface managed by CAPsMAN (6)
Tried to do it from Quickset as well without success.
Is there a way to disable CAPsMAN or make it allow my Wifi networks?
hecatae
Thu Aug 25, 2022 7:33 pm
I'd be netinstall the latest stable release 7.4.1
https://help.mikrotik.com/docs/display/ROS/Netinstall
dnielr
Re: Chateau LTE admin panel cannot be reached even after Factory reset  [SOLVED]
Thu Aug 25, 2022 8:24 pm
Resolved with the followin video:
https://www.youtube.com/watch?v=oGv5_FB76mE
CPSMAN enable check has been removed under Wireless interfaces / CAP menu
Users browsing this forum: Google [Bot] and 60 guests
