Abdelhadi
No connection between device (AP) and MTK
Thu Aug 25, 2022 3:29 pm
Hi everyone,
I have a connection problem between my Mikrotik router and a Vodafone router that I want to use as AP.
Basic info:
Mikrotik: CCR2004
Vodafone: H500-S
RouterOS: 7.4.1
This is what I did:
Because I'm using a SFP-RJ45 module, I disabled auto negotiation and limited the rate to 1Gbps
I made a bridge between interfaces, including the interface I'm using to connect the AP
In the firewall, I activated NAT/masquerade
All devices in my network (Directedly connected to the MTK or thought a switch) are working fine and had access to internet.
The only device not working is this AP: I can't ping from and the two devices! The AP can't get an IP from the DHCP of the MTK...
[Update]
When I connect the AP with the switch (Connected to the MTK), the AP can get IP address and DNS, and internet (ping 8.8.8.8).
But I remarqued that when I'm connected with PC to AP's wifi, I can't reach internet, and the problem of ping between the AP and the MTK still no resolved.
I'm new in Mikrotik devices, and I believe I'm missing a basic thing.
Thank you in advance.
anav
Re: No connection between device (AP) and MTK
Thu Aug 25, 2022 10:48 pm
Probably but how can I best investigate the issues....... Crystal ball, tarot cards, speculating........
OR
post network diagram
and
/export config (minus public WANIP info)
Abdelhadi
Fri Aug 26, 2022 12:01 pm
Thanks for your reply.
Attached the diagram.
Next, the config:
# aug/26/2022 09:57:17 by RouterOS 7.4.1
# software id = 1FG4-CGSK
# model = CCR2004-1G-12S+2XS
# serial number = D4F00C20652D
add name=LAN1-INFO_Bridge
set [ find default-name=ether1 ] comment="Management Port" name=\
"Ethernet1-Mgmt Port"
set [ find default-name=sfp-sfpplus1 ] name="SFP+01->Dell T430 DAC1"
set [ find default-name=sfp-sfpplus2 ] name="SFP+02->Dell T430 DAC2"
set [ find default-name=sfp-sfpplus3 ] name="SFP+03->INFO2 (Local C)"
set [ find default-name=sfp-sfpplus4 ] name="SFP+04->INFO3 (LocalC)"
set [ find default-name=sfp-sfpplus5 ] name="SFP+05->INFO1 (Local D)"
set [ find default-name=sfp-sfpplus6 ] name="SFP+06->Dell R820 DAC1"
set [ find default-name=sfp-sfpplus7 ] name="SFP+07->Dell R820 DAC2"
set [ find default-name=sfp-sfpplus8 ] name="SFP+08->HP DL 360 DAC1"
set [ find default-name=sfp-sfpplus9 ] name=SFP+09
set [ find default-name=sfp-sfpplus10 ] name=SFP+10
set [ find default-name=sfp-sfpplus11 ] auto-negotiation=no comment=\
"AP1_Local D" name=SFP+11->AP1
set [ find default-name=sfp-sfpplus12 ] auto-negotiation=no comment=\
"To IAM Modem 192.168.2.1" name="SFP+12-> IAM Modem"
set [ find default-name=sfp28-1 ] name=SFP28-01
set [ find default-name=sfp28-2 ] name=SFP28-02
add name=WAN
add name=LAN1-INFO
add name=LAN2-CAM
add name=dhcp_pool0 ranges=192.168.8.100-192.168.8.200
add address-pool=dhcp_pool0 interface=LAN1-INFO_Bridge lease-time=11m name=\
dhcp1
/port
set 0 name=serial0
set 1 name=serial1
add bridge=LAN1-INFO_Bridge interface="SFP+01->Dell T430 DAC1"
add bridge=LAN1-INFO_Bridge interface="SFP+02->Dell T430 DAC2"
add bridge=LAN1-INFO_Bridge interface="SFP+05->INFO1 (Local D)"
add bridge=LAN1-INFO_Bridge interface="SFP+03->INFO2 (Local C)"
add bridge=LAN1-INFO_Bridge interface="SFP+04->INFO3 (LocalC)"
add bridge=LAN1-INFO_Bridge interface="SFP+06->Dell R820 DAC1"
add bridge=LAN1-INFO_Bridge interface="SFP+07->Dell R820 DAC2"
add bridge=LAN1-INFO_Bridge interface="SFP+08->HP DL 360 DAC1"
add bridge=LAN1-INFO_Bridge interface="SFP+12-> IAM Modem"
add bridge=LAN1-INFO_Bridge interface=SFP+11->AP1
add address=192.168.3.1/24 comment=defconf interface="Ethernet1-Mgmt Port" \
network=192.168.3.0
add address=192.168.2.2/24 comment="Connect to IAM Modem: 192.168.2.1" \
interface="SFP+12-> IAM Modem" network=192.168.2.0
add address=192.168.8.1/24 interface=LAN1-INFO_Bridge network=192.168.8.0
add address=192.168.8.0/24 dns-server=192.168.8.5,8.8.8.8 gateway=192.168.8.1
set servers=192.168.8.5,8.8.8.8
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/system clock
set time-zone-name=Africa/Casablanca
/system identity
set name=DSTM-MTK
/system ntp client
set mode=broadcast
/system ntp client servers
add address=id.pool.ntp.org
anav
Sat Aug 27, 2022 9:15 pm
Why is WAN port on LAN bridge??
From what you included in your config (only a partial it seems), thats all I see.
Abdelhadi
Tue Aug 30, 2022 8:25 pm
Thanks for replying.
I did the modification by removing WAN port from LAN bridge.
But this didn't resolve the AP problem: The MTK sill not "seeing" the AP directly connected to the MTK.
When I plug the AP in a no Mikrotik router I can ping between the two devices, and the AP gets internet in addition!
Once replaced under MTK, it doesn't work.
I suspect a firewall blocking rule in the MTK.
Any idea?
Thanks.
anav
Tue Aug 30, 2022 9:50 pm
I already told you.
Please post FULL Config of both MT and AP. ( one that shows the firewall rules not part of the config )
add action=masquerade chain=srcnat missing out-interface-list=WAN
since its a fixed IP better is
add action=src-nat chain-srcnat to-addresses=192.168.2.2 out-interface="SFP+12-> IAM Modem"
Abdelhadi
Wed Aug 31, 2022 2:09 pm
next the config:
# aug/31/2022 12:06:11 by RouterOS 7.4.1
set [ find default-name=ether1 ] comment="Management Port" name=Ether1
set [ find default-name=sfp-sfpplus1 ] comment="->Dell T430 DAC1" name=SFP+01
set [ find default-name=sfp-sfpplus2 ] comment="->Dell T430 DAC2" name=SFP+02
set [ find default-name=sfp-sfpplus3 ] comment="->INFO2 (Local C)" name=SFP+03
set [ find default-name=sfp-sfpplus4 ] comment="->INFO3 (LocalC)" name=SFP+04
set [ find default-name=sfp-sfpplus5 ] comment="->INFO1 (Local D)" name=SFP+05
set [ find default-name=sfp-sfpplus6 ] comment="->Dell R820 DAC1" name=SFP+06
set [ find default-name=sfp-sfpplus7 ] comment="->HP DL360e DAC1" name=SFP+08
set [ find default-name=sfp-sfpplus11 ] auto-negotiation=no comment="AP1_Local D" name=SFP+11
set [ find default-name=sfp-sfpplus12 ] auto-negotiation=no comment="IAM Modem 192.168.2.1" name=SFP+12
add name=WAN
add name=LAN
add address-pool=dhcp_pool0 interface=LAN1-INFO_Bridge lease-time=11m name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
disabled=yes disabled=yes name=zt1 port=9993
add bridge=LAN1-INFO_Bridge interface=SFP+01
add bridge=LAN1-INFO_Bridge interface=SFP+02
add bridge=LAN1-INFO_Bridge interface=SFP+03
add bridge=LAN1-INFO_Bridge interface=SFP+04
add bridge=LAN1-INFO_Bridge interface=SFP+05
add bridge=LAN1-INFO_Bridge interface=SFP+06
add bridge=LAN1-INFO_Bridge interface=SFP+08
add bridge=LAN1-INFO_Bridge interface=SFP+09
add bridge=LAN1-INFO_Bridge interface=SFP+10
add interface=LAN1-INFO_Bridge list=LAN
add interface=SFP+12 list=WAN
add address=192.168.2.2/24 interface=SFP+12 network=192.168.2.0
add action=masquerade chain=srcnat out-interface=SFP+12
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/system clock
/system gps
set set-system-time=yes
/system identity
set name=DSTM-MTK
/system ntp client
set mode=broadcast
anav
Wed Aug 31, 2022 2:46 pm
Okay I will assume you have no firewall rules and thus please install the following.......
{Input Chain}
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
{forward chain}
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward
Abdelhadi
Thu Sep 01, 2022 12:25 pm
I add rules you sent, but the AP still not getting connection from the MT.
What is strange, is that when I take the AP and I plug it the the Cisco switch, all works fine! Once plugged directly to MT, it doesn't work: no ping, no internet.
The config:
set [ find default-name=sfp-sfpplus3 ] comment="->INFO2 (Local C)" name=\
SFP+03
set [ find default-name=sfp-sfpplus5 ] comment="->INFO1 (Local D)" name=\
SFP+05
add name=WAN
add name=LAN
dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/zerotier
invalid
connection-state=invalid
add action=accept chain=forward comment="allow internet traffic" \
add action=accept chain=forward comment="allow port forwarding" \
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
192.168.2.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=\
no target-scope=10
/system clock
/system gps
/system identity
set name=DSTM-MTK
/system ntp client
set mode=broadcast
Many thanks
anav
Re: No connection between device (AP) and MTK  [SOLVED]
Thu Sep 01, 2022 1:38 pm
Did you set the IP address manually in the MT.
Go to DHCP leases add the ip address and the mac address of the AP. not much else I can think of.
Abdelhadi
Thu Sep 01, 2022 5:41 pm
Hi Anav,
I added the mac of 2 APs, and things seem working for now.
I'm thankful for your patience and help.
PS: the two addresses I added are in "waiting" statut, I don't know if does matter ....
Can I ask you briefly (Cause I should open one other topic for this): As you saw in the diagram in my first post, my MT is behind an ISP modem. It have a public IP. witch way should I explore to do a remote access to my LAN (example my MT) from the WAN (Forwarding ports, VPN, cloud....). I'm looking for security first.
Thanks a lot.
anav
Thu Sep 01, 2022 7:20 pm
Ensure you update to version 7.5 latest stable firmware and use Wireguard.
viewtopic.php?t=182340
From where and what devices do you plan on accessing the router for config purposes or its subnets to access data ???
Abdelhadi
Thu Sep 01, 2022 7:38 pm
For update, I'm planning to do it this weekend cause I can't during production time...
For remote access, I want to access the MT from PC for config trough Winbox, may be accessing also some PCs in my LAN ...
Thank you.
anav
Thu Sep 01, 2022 9:34 pm
Assuming you dont have an MT router at home so a windows client on the pC should work.
As well if you have an IOS device it will work with wireguard client.
I use my iphone with wireguard client and then use the mikrotik app to config the router
Users browsing this forum: Amazon [Bot], Bing [Bot], qatar2022 and 102 guests
