sami935
switching to SW
Thu Aug 25, 2022 5:12 pm
GREETINGS,
I switched to SWOS trying to do some vlan testing but when the switch reboots I can't access to it from the winbox nor from the default address any help please?
bpwl
Re: switching to SW  [SOLVED]
Thu Aug 25, 2022 8:05 pm
SWOS is not managed by WinBox, only HTTP/HTTPS
Reason: HTTPS is not supported on SwOS
k6ccc
Re: switching to SW
Fri Aug 26, 2022 6:09 pm
In the Neighbors tab half way down the screen in WinBox where you select what system to connect to, you MIGHT see your switch (depends on a setting in the switch). Selecting it there will bring up a browser session.
sami935
Re: switching to SW
Fri Aug 26, 2022 6:41 pm
thanks I ffigured that out after few tries
thanks for your reply
sami935
Re: switching to SW
Fri Aug 26, 2022 6:42 pm
thank you sir i just figured that out
thanks a lot
chechito
Re: switching to SW
Fri Aug 26, 2022 7:02 pm
i did not know SWOS supports HTTPS management
rextended
Re: switching to SW
Fri Aug 26, 2022 7:27 pm
Do not have any support for httpS
bpwl
Re: switching to SW
Sat Aug 27, 2022 12:27 am
No HTTPS, (no support for certificates etc.)
Users browsing this forum: No registered users and 32 guests
