Cray
RouterBOARD 1200 (RB1200) issues with RouterOS v7
Fri Aug 26, 2022 8:49 am
RouterBOARD 1200 (RB1200) is able to install and upgrade to ROS 7.x, but loses connectivity on ethernet ports 1-8, while ports 9 and 10 remain accessible.
To summarize:
  • RouterOS v7.x installs ok
  • Ports 1-8 negotiate links, leds work as expected, but no L2 or IP traffic flows.
  • Ports 9 and 10 work ok and all features are able to use them.
  • Through ports 9 and 10, all ROS features I tested work as well as in comparable devices running ROS v7.x
When resetting default configuration the device binds default IP 192.168.88.1 only to ether1. This leaves serial port the only way to regain access to the device and set active IP to ports 9 and/or 10.
As of this writing I've verified this port issue with latest RouterOS v7.4.1 and 7.5rc1.
My ticket number with MikroTik support is SUP-90869
gbetsis
Re: RouterBOARD 1200 (RB1200) issues with RouterOS v7
Fri Aug 26, 2022 5:29 pm
I have the same exact problem.
I have upgraded my RB1200 from RouterOS v6.49.6 to v7.4.1 and I have noticed that ether1-ether8 stopped working.
1) The is link for all those Ethernet ports is flapping (up/down state).
2) DHCP request are send out, but response is never picked up
3) PPPoE client that runs on those ports does not work.
I downgraded to 7.3.1, 7.2.3 and 7.1.5 but the problem still exists.
As soon as i downgrade to 6.49.6 the unit is working fine.
I have done a “reset-configuration” without keeping the defaults, on all those versions, and the problem still exists.
Ether9 and Ether10, works just fine.
As you can see on the RB1200 diagram (https://i.mt.lv/cdn/product_files/RB1200_180301.png), the first 8 ports are on an Atheros8327 switch, and the last 2 ports (ether9 and ether 10) are on a PCIe controller.
I think that this is the problem. The drivers for the Atheros8327 are bad on RouterOS v7.x.x
I have submitted ticket number SUP-90933 on Mikrotik support.
mkx
Fri Aug 26, 2022 10:04 pm
According to block diagram posted in previous post,
  • ports 1-5 are connected to ar8327 switch chip
  • ports 6-8 are connected directly to SoC
  • ports 9-10 are connected to PCIe controller(s)
Which rather indicates that something is wrong with handling of ethernet ports of PPC460GT SoC in v7. PPC460GT features 4 gigabit ethernet ports, of which one is connected to AR8327 switch chip.
BTW, I've got a few RB951Gs running v7 without such problems. RB951G also uses AR8327 switch chip, so support for AR8327 in v7 seems to be just fine.
Cray
Sun Aug 28, 2022 9:17 pm
I received following response from MikroTik support to my RB1200 ticket:
Thank you for contacting MikroTik Support.
Thanks for the reports, we will see what can be done here, meanwhile please use ROS 6.48.6.
Cray
Sun Aug 28, 2022 9:20 pm
Also wAP R ac (RBwAPGR-5HacD2HnD) uses Atheros 8327 and works wonderfully with v7.4.1 and v7.5rc1.
I agree that the issue is must not be with support for AR8327 switch chip in v7 kernel.
Cray
Sun Aug 28, 2022 9:27 pm
RouterBoard very close to RB1200, the RB1100AHx2 also uses PPC CPU and AR8327 switch chips:
https://wiki.mikrotik.com/images/e/ed/R ... treams.png
It is fully working with ROS v7 releases.
Znevna
Sun Aug 28, 2022 9:49 pm
But not the same SoC..
gbetsis
Mon Aug 29, 2022 10:43 am
I have received the following response from the support team:
Thank you for the report, we will try to resolve this issue in future releases. Sorry for the inconvenience.
Cray
Mon Aug 29, 2022 11:54 pm
That sounds promising!
ilnicchio
Tue Sep 27, 2022 4:42 pm
Same problem here... with 7.5.... some news?
leoirssi
Tue Oct 04, 2022 7:55 pm
Great, really looking forward for working 7.* version on RB1200 :)
ananclub
Tue Oct 11, 2022 6:28 am
The same problem, want some good new.
leoirssi
Tue Nov 08, 2022 5:46 pm
Did anyone try 7.6 on RB1200?
KOK
Thu Nov 24, 2022 11:46 pm
Is there any news about this issue?
I can confirm that the problem still persist in 7.6
chechito
Fri Nov 25, 2022 5:13 am
in which year was RB 1200 introduced ?
rextended
Fri Nov 25, 2022 7:15 pm
The RB1200 model was finalized in February 2011 (RouterOS 5.0 was released in March 2011)
"Mass production" started in April 2011, with Factory software RouterOS 5.2 (2011-Apr-21 09:36) on powerpc
The RB1200 is first announced on Newsletter #31 of May 2011
Just 11 years ago, 2 RouterOS versions before and discontinued architecture that is no longer being developed…
holvoetn
Fri Nov 25, 2022 8:36 pm
And, your point being ?
I've got a 2008 Dell laptop working just fine with latest Dietpi distro (debian based).
That's the one I use for netinstall :lol:
chechito
Fri Nov 25, 2022 9:04 pm
yeah but not with windows 11 for example
BillyVan
Fri Nov 25, 2022 9:26 pm
i have RB1100AHx2 working with ros 7.6
and RB1200 not working
i thing both are 2011 models
rextended
Fri Nov 25, 2022 11:03 pm
Not only "my"...
You can not compare platforms like x86 (and even 64) currently supported and developed (apple switched more than 11 years ago from powerpc to x86...)
and you cannot compare open source platforms with closed source (where it suits them) platforms.
I'm sorry, but even here the comparison is wrong, because with windows 11 Microsoft wants to cut out the previous ones ON PURPOSES,
and not simply no longer support the "old" hardware.
In fact I'm using Windows 11 on a test pc, but the pc has absolutely none of the mandatory new features, compared to windows 10,
but still work perfectly with Win10 drivers, without TPM and all the other useless frills.
And even here I can "modify" windows 11 to make it go by force, but I can't modify, for example, the drivers that are not in ROS v7 for the switch that is only in the RB1200 (and not in the RB1100)
chechito
Fri Nov 25, 2022 11:25 pm
i think RB1100ahX2 was available up to a much more recent time than rb1200, for example when RB3011 was introduced in 2015 RB1100ahX2 was still on sale and available, RB1100ahX2 was discontinued when RB1100ahX4 versions arrived around 2017
so rb1100ahx2 is a little more actual than rb1200, because of that has better chance of still being compatible and supported, but not for too much time
rextended
Fri Nov 25, 2022 11:33 pm
they left the same name, but the "old" is powerpc, the other is ARM...
chechito
Fri Nov 25, 2022 11:37 pm
yeah i know, the X4 share many components with RB4011
rextended
Fri Nov 25, 2022 11:47 pm
RB1100: February 2010 [PowerPC NXP MPC8533VTALF]
RB1100AH: December 2011 [PowerPC NXP MPC8533VTALF]
RB1100AHx2: March 2011 [DUAL Core PowerPC NXP P202ASSE2KFB] 2G
RB1100AHx2-LM: April 2011 [DUAL Core PowerPC NXP P202ASSE2KFB] 512M
RB1200: May 2011 [PowerPC AMCC PPC460GT-NUA600T]
(@mkx is not MACOM, is AMCC)
I do not test RB1100/RB1100AH, but probably the NXP still supported and AMCC not...
gotsprings
Sat Nov 26, 2022 12:07 am
Mine lost ports 9 and 10 like a decade ago.
Cray
Mon Mar 13, 2023 1:47 pm
Just tested with latest RouterOS 7.8 and RB1200.
Not looking good.
Same results:
  • Ports 1-8 connect but no traffic is flowing through
[admin@MikroTik] /interface/ethernet/switch> print
Columns: NAME, TYPE
# NAME     TYPE
0 switch1  Atheros-8316
duzorg
Wed May 03, 2023 9:19 am
RouterOS 7.9
ports 1-8 not working.
there doesn't seem to be a fix ((((
rextended
Wed May 03, 2023 11:03 am
RouterOS 7.9
And never is fixed, use 6.48.6 and do not pretend to install one fresh RouterOS for 12 years old model with unsupported chipset on v7.
horakus
Wed Nov 15, 2023 11:28 pm
Hi
I had the same problem...
It seems that, starting with RouterOS v7 something changed. All the packages that used to be listed under routeros-powerpc (in RouterOS v6) are now integrated into the main package. Somehow, the routerboard can not access or install them. The functionality is 'crippled'... :)
I've downgraded to RouterOS v6.49.10 via netinstall and all is working, flawlessly, again!
Just to check, after upgrading again to RouterOS v7 it did not work...
Users browsing this forum: No registered users and 161 guests
