electravis
rename file on ftp upload
Fri Aug 26, 2022 4:51 pm
I am trying to rename a file during the ftp upload process. I want to give it the date and timestamp of the upload time. However I cant seem to figure out the variable or if its even allowed on an ftp upload. The upload works fine if i give the file a static name but not what i am trying to do.
:local date [/system clock get date]
:local time [/system clock get time]
/tool fetch address=xxx.xxx.xxx.xxx src-path=testfile.txt user=xxxxx mode=ftp password=xxxxxx dst-path="[$date][$time].txt" upload=yes;
rextended
Re: rename file on ftp upload  [SOLVED]
Fri Aug 26, 2022 6:20 pm
(use search function before open new topic)
This is not a question of knowing or not RouterOS, this is the A-B-C of operating systems.
again same error horror: on time and date are present special characters that do not fit as filename on file system
aug/26/2022 = folder aug / folder 26 / folder 2022....
Use this (and search button is your friend)
:global arrMonths {jan="01";feb="02";mar="03";apr="04";may="05";jun="06";jul="07";aug="08";sep="09";oct="10";nov="11";dec="12"}
/system clock
:local ndate  [get date]
:local ntime  [get time]
:local fdname "$[:pick $ndate 7 11]$($arrMonths->[:pick $ndate 0 3])$[:pick $ndate 4 6]$[:pick $ntime 0 2]$[:pick $ntime 3 5]"
/tool fetch mode=ftp upload=yes address=xxx.xxx.xxx.xxx user=xxxxx password=xxxxxx src-path=testfile.txt dst-path="$fdname.txt"
electravis
Mon Aug 29, 2022 3:30 pm
Thank you
Users browsing this forum: UkRainUa and 30 guests
