project2501
hAP ac² - Apple Time Machine support via attached USB hard drive?
Sat Aug 27, 2022 6:57 pm
Apple Time Machine support via USB hard drive?
I am running an hAP ac² on 6.48.6
https://mikrotik.com/product/hap_ac2#fn ... ifications
Is it possible to configure Samba to use an attached USB hard drive as a target for Apple Time Machine backup?
If yes: how?
I have found
https://wiki.mikrotik.com/wiki/Manual:System/Disks
https://wiki.mikrotik.com/wiki/Manual:IP/SMB
Thank you
nichky
Re: hAP ac² - Apple Time Machine support via attached USB hard drive?
Sun Aug 28, 2022 7:56 am
do u want your config as a backup?
gdanov
Mon Aug 29, 2022 11:07 am
Time machine on samba needs some extra config (when done on linux) and I doubt that's possible to configure on MT.
nichky
Mon Aug 29, 2022 12:39 pm
not sure what exactly you mean by that, but here is my e.g., hope u can find some useful,gl
/system logging action
add disk-file-name=/usb/log name=usb target=disk
add action=usb prefix=usb topics=ipsec
/ip smb
set allow-guests=no enabled=yes
/ip smb shares
add directory=usb/ name=data
/ip smb users
add name=name password=pasword read-only=no
project2501
Mon Sep 05, 2022 3:06 pm
Hello nichky,
no config backup - I want to back up my Mac's using time machine.
I also have read into the Linux topic with the extra configuration effort to get Time Machine up and running.
Hence I wanted to ask if someone got it working on a hAP ac²
IslaMujeres
Sun Jun 11, 2023 12:12 am
Did you manage to find an answer? Cause i just read a great article about the time machine and ways to use it in this blog https://www.macgasm.net/news/tips/how-t ... e-machine/. I bet you will find all the answers to your questions thereю The very important point here - create a time machine backup for the unexpected power loss for example. The instructions in this blog are pretty simple and people without special technical knowledge can manage it as well. Good Luck
project2501
Sun May 19, 2024 7:45 pm
Hello @IslaMujeres
no luck so far:
I have set up a regular smb share:
https://help.mikrotik.com/docs/display/ROS/SMB
ext4
Time Machine does complain with an error message not being able to find a valid target.
In macOS 14.4.1 (23E224) Finder I am able to access the MT samba share, read and write.
project2501
Sun May 19, 2024 7:50 pm
Is this really necessary?
https://wiki.samba.org/index.php/Config ... h_Mac_OS_X
Where would I edit this on ROS?
normis
Mon May 20, 2024 10:39 am
Since this topic was started, all SMB implementation has been changed in RouterOS. Upgrade to v7.15 and reset all SMB settings, then try again to configure it from beginning. New SMB implementation in RouterOS could mean completely different result
Users browsing this forum: anserk, gfunkdave and 84 guests
