jhbarrantes
Error trying to read on-up context for PPPoE profile in v7.4.1
Sat Aug 27, 2022 7:36 pm
I'm having problems when trying to read PPPoE profile context in v7.4.1. As per documentation, it seems the following items are exposed as context for this script: https://help.mikrotik.com/docs/display/ ... erProfiles
  • user
  • local-address
  • remote-address
  • caller-id
  • called-id
  • interface
I would like to read interface value, but when printing this in logs, this is what I get (which is not the interface name, what I think is the expected)
On-up script, inside PPPoE custom profile (copy from default)
/log warning $interface
Could someone test the same in v6 and check if that is printing the correct interface name there? Just to confirm if it is a bug or not. And please tell me if you think I'm doing something wrong, script couldn't be easier. For reference, I was able to read properly "local-address" field, printing the current public IP for this interface.
Thanks!
rextended
Re: Error trying to read on-up context for PPPoE profile in v7.4.1  [SOLVED]
Sun Aug 28, 2022 4:52 am
Work exactly as expected.
Also on v6 you obtain the id of the interface.
For get the interface name you must request the name...
/log warning [/interface get $interface name]
jhbarrantes
Sun Aug 28, 2022 11:28 am
Amazing, thanks rextended!
Users browsing this forum: Google [Bot] and 39 guests
