darksideofme
UserManager 7.3.1 - Time Problem
Sun Aug 28, 2022 1:01 pm
Hi
im a new user to mikrotik and im start to learning new things.
running V7.3.1 and have a problem with correct time set on usermanager service
i se the profiles for limited time access but when i check the user profiles, for limited users, had a two probelm
its a 1month access profile
State: show me waiting
End Time:Jan/01/1970 04:29:58
how can i fix that?
thanks in advance
own3r1138
Long time Member
Long time Member
Re: UserManager 7.3.1 - Time Problem
Sun Aug 28, 2022 10:03 pm
Reza
You should enable using the profile first. After initiating the first connection, the user profile will show the correct time.
ikomeyl
Sat Dec 24, 2022 4:15 pm
Is this problem solved?
Unfortunately, in addition to this, there is also the problem of resetting users' traffic after a certain period, which cannot be solved!
own3r1138
Long time Member
Long time Member
Wed Dec 28, 2022 11:12 am
"resetting users' traffic after a certain period" did you try this?
ikomeyl
Wed Dec 28, 2022 11:30 am
Exactly this method does not work and it does not reset in a specified time period
ikomeyl
Wed Dec 28, 2022 11:33 am
Reza
dont work!!!
own3r1138
Long time Member
Long time Member
Wed Dec 28, 2022 12:33 pm
The profile and start time work fine for me. You should check your initiated config. I didn't use the limitation reset, so I can't confirm your findings.
Users browsing this forum: No registered users and 11 guests
