MUM Europe 2020
ngaleyev
Rate limiting subnet with fixed per user bandwidth
Tue Oct 02, 2007 1:07 am
Hi all,
I'm trying to rate limit my customers to 512k/128k no more or less.
I tried different setups for queues including pcq's for uploads and downloads separately.
If I apply queue to a subnet address, 192.168.0.0/24, it shares bandwidth evenly between all users in that subnet, e.g. if i rate limit subnet to 512kbps, and i got 10 users, i will get ~50kbps per user, but I want to rate limit that subnet to 512kbps and get 512kbps for each user.
I know there is a way to do it by writing individual queues for every user, but i've got around 600 users on that subnet (/22 actually), and even if i create these queues with a script, it may create a excessive cpu load (running mikrotik on 700mhz amd)
My question is: is there a way to create rate limiting rules applied to a subnet, that specify bandwith limit per user individually?
Chupaka
Re: Rate limiting subnet with fixed per user bandwidth
Tue Oct 02, 2007 2:03 am
revert to queue type = pcq, but do not limit overall queue, set limits only in queue type definition
sariao
Tue Oct 02, 2007 2:22 am
PCQ is used exactly to achieve what you want.
Follow the steps:
http://wiki.mikrotik.com/wiki/PCQ_Examples
digicomtech
Tue Oct 02, 2007 3:30 am
Could it be a NAT issue ?
Reading manual packet flow:
Global Out-Queue is before Source NAT
is it right ?
local
mangle
pcq queue
NAT
public
fatonk
Tue Oct 02, 2007 4:57 pm
your question:
My question is: is there a way to create rate limiting rules applied to a subnet, that specify bandwidth limit per user individually?
Has been answered, just check the wiki example for PCQ:
I have used since a long time this queuing technique and have no problem, when you setup this just post your configuration here and someone can check for any mistake.
Regards.
Faton
Caci99
Thu Oct 04, 2007 5:00 pm
Pershendetje Faton, mund te me kalosh adresen tende te email?
-Toni-
Don't crash the ambulance, whatever you do
fatonk
Thu Oct 04, 2007 5:23 pm
tung,
adresa ime eshte:
fatonkurteshi@yahoo.com
pershendetje
fatoni
oscarBravo
Sun Oct 07, 2007 11:04 pm
Is it possible to apply bursting using this technique?
oscarBravo
Tue Oct 09, 2007 1:14 pm
Apologies for bumping this, but it's something I'd really like to figure out.
I've set up PCQ shaping using simple queues, but the capability to burst to a higher speed is important. I'm wondering if I can create a bursting queue type, and use a PCQ queue type as its parent in queue trees? Am I even heading in the right direction with this?
chvdr
Wed Oct 10, 2007 9:22 am
Hi all,
Actually this is not an easy question. You need maybe several days to read all in this forum. It's a tone of posts here. The main problem with bursts is that if somebody reaches the burst, it's difficult and slow to take from it over traffic. Shapers works slow and not absolutely correct. Some peoples uses adv. techniques such as bridge with one queue tree and router with simple queues after that... Read closely all posts you reach in the forum. That will help you to find out some good decision.
Re,
C. G.
chvdr
Wed Oct 10, 2007 9:32 am
tung,
adresa ime eshte:
pershendetje
fatoni
Dear fatonk,
I personally prefer french. But everybody in this forum uses english. Is it possible to repeat your post, in english this time.
apolog., it's in principle, nothing person. in that message.
C. G.
jorj
Wed Oct 10, 2007 12:03 pm
/22 queue for each individual address is not that much for a 700 hmz x86.
I have queues for 3 /24 net, each with burst and band limit, on a 500 mhz pII. Doing just fine. cpu 15-30% at all times. ( for about 300 users. Different limits, from 256 to 768k.)
Users browsing this forum: chirba4, Google [Bot], rviteri and 89 guests
