froszu
mounting the device with magnets
Mon Aug 29, 2022 3:44 pm
Hey!
A (maybe) stupid question here. I want to mount my router (LtAP mini LTE kit) with a few neodymium magnets.
Can this (static but strong) magnetic field interfere with router operation ?
honest quiestion !
thanks
cdemers
Re: mounting the device with magnets
Sat Sep 03, 2022 4:09 am
Possibly can cause problems. If you want to do this I would attach a steel (ferrous/magnetic) plate to the bottom of the device (as large as the bottom of the device) and mount the magnets to that. The metal will act as shielding for the magnets, the stronger the magnets the thicker the metal should be.
vecernik87
Forum Veteran
Forum Veteran
Sat Sep 03, 2022 4:21 am
Given the fact that mAP lite has mounting magnets built in, I highly doubt that it would have any serious effect.
Sob
Sat Sep 03, 2022 5:09 am
It had some effect on mAP lite: viewtopic.php?t=104540
fragtion
Sat Sep 03, 2022 7:18 am
I had to remove the magnets from my map lite it was causing stability problems
Users browsing this forum: patrikg and 100 guests
