muk
wifi connectivity issue in RB951G-2HnD
Mon Aug 29, 2022 6:02 pm
Hi.....
Dear Team...
i have RB951G-2HnD router board with upgraded version v7.4.1. in this router board enable the Wireless mode and assign the ip pool.
All Windows based systems (Desktop & Laptop) and Android Phone are connected to MikroTik Wi-Fi, but Apple Devices (I-Phone & MAC Book) are not connected to MikroTik Wi-Fi.
many times trying to connect the Wi-Fi but still showing same error "Unable to Connect this Network).
need your suggestions.
Gh0sTPaPa
Re: wifi connectivity issue in RB951G-2HnD
Tue Aug 30, 2022 2:10 am
Hi friend , when going to security profiles disable the bottom two.
WPA EAP WPA2 EAP
This runs your wireless network in a "enterprise" level apple devices don't like this.
Should do the trick otherwise I suggest playing around with frequency.
danielcs
Tue Aug 30, 2022 4:15 am
I recommend you check in Advanced > Preamble Mode and the encryption as indicated by @Gh0sTPaPa.
nichky
Tue Aug 30, 2022 6:47 am
@muk
what u getting on the log?
/system logging action
add name=wlan target=memory
add action=wlan topics=wireless,!debug
nichky
Tue Aug 30, 2022 6:51 am
what @danielcs suggesting , i was reading about that , would be the one of the solutions, you can play with that , do not ask me what is the difference between short log both, i really cant answer that
Users browsing this forum: filou59 and 46 guests
