JustAnAccount
Reset Wireless Wire Cube Pro to Default config
Tue Aug 30, 2022 5:19 pm
Good afternoon
I a set of pre configured Wireless Wire Cube Pro. From my understanding they should act like a cable with their default config. I am afraid past me made some changes on them. If I reset them; will the default config (pre configured) come back? Or will they be blanco?
rextended
Re: Reset Wireless Wire Cube Pro to Default config
Tue Aug 30, 2022 5:23 pm
is "blanco" only if you select "no default config"
remember to check before reset if the sticks with password still are present on case an readable
Users browsing this forum: No registered users and 83 guests
